Reply
WAX630 - Installed but set up 2 wifi networks in errot
aguden_guden_co
Apprentice
I added 2 WAX6302 and when I did I created 2 separate WiFi networks in error.  I wanted them to both be in the same wifu network.  How can I change that?  New to this concept of WiFi networks and I am sure my next question will be about mesh networks!
Message 1 of 3
Accepted Solutions
schumaku
Guru
Re: WAX630 - Installed but set up 2 wifi networks in errot
Alternate to Insight (not available in all countries, small cost, ...) it's possible to manage the WAX individually. On Management > Configuration > Wireless > Basic you can select the SSID you intend to change, then change the name, security PSK, ... to the same value like the other access point.
Message 3 of 3
All Replies
Guru
If you start at page 44 of the manual it goes over setting up an Insight managed mesh network.
They should come with 1 year of insight included.
WAX630 | Insight Managed Access Point | NETGEAR Support
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 3
schumaku
Guru
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 470 views
  • 0 kudos
  • 3 in conversation
Announcements
