Reply
WAX630 constantly dissasociating a host
jeconti
Tutor
Hi all,
I have a WAX630, original not WAX630E. It is constantly dissociating a single host over and over. In a nonstop 30 second cycle of authentication and connecting then dissociating.
Now this device has worked flawlessly for years, but ever since upgrade from 10.7.X major release this has been happening. I do not want to downgrade due to security concerns, so I would rather troubleshoot this host.
The logs are here.
https://pastebin.com/EzgKK06Q
This is a smart wifi power strip, with routines to turn lights on and off at certain hours. It is on it's own SSID of Monoprice (Created just for this purpose) broadcasting exclusively 2.4ghz for this device. This configuration works flawlessly in older releases and if I downgrade, but once I upgrade to a 10.7 release it all breaks.
Any ideas? What can I do to fix this?
Message 1 of 5
prasingh
Re: WAX630 constantly dissasociating a host
Message 2 of 5
Pramendra
NETGEAR Expert
Hi @jeconti ,
We will get the logs checked on our side. In the meantime can we please try once changing the 2.4 GHz config (password) and forget the SSID on the device and try re-connecting back if that helps?
Thanks!
Pramendra
NETGEAR Wireless Team
Message 3 of 5
jeconti
Tutor
No difference on my end. Have you any other ideas or suggestions?
Message 4 of 5
Pramendra
NETGEAR Expert
Hi @jeconti
l will reach out to you in a DM to get more details regarding this.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 303 views
  • 0 kudos
  • 3 in conversation
Announcements
