Reply
WC7600 Captive Portal and VLAN
Andreas123
I have a WC7600 and 10 Aceesspoints in VLAN 6, IP 10.xx. The guest network is VLAN 5, 192.168.1.xx. Both networks can access the internet, but there is no routing in between. The captive portal is only on the IP address of the controller and can not be reached from the guest network. How is this usually solved? Ideal would be another address of the controller in VLAN 5, but I can not find it.
Model: WC7600|ProSafe Wireless Controller
Message 1 of 4
Accepted Solutions
Andreas123
Re: WC7600 Captive Portal and VLAN
Problem solved, it was a misconfigured switch on the way to the access point.
Message 4 of 4
All Replies
Andreas123
Betreff: WC7600 Captive Portal and VLAN
or do I need a route from the guest network to the management network to reach the captive portal?
Message 2 of 4
RaghuHR
NETGEAR Expert
Hi @Andreas123
Could you please help us to understand your issue with network diagram? Also share your configurations.
Thanks,
Raghu
Message 3 of 4
Andreas123
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2402 views
  • 0 kudos
  • 2 in conversation
Announcements
