- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WFS709tp ssh enable password?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi!
Prompt the password for "enable" at an entrance on ssh on the controller.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Alexdbv,
Welcome to the community!
I just like to inform you that the enable password is reserved for engineering/support use only. It is also not possible to set enable password on the GUI or using the console, this is normally the case when the enable function is reserved for engineering use only. This is not for end-user usage.
Thanks,
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Alexdbv,
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WFS709tp ssh enable password?
Hi Alexdbv,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
