Reply
WNDAP350/WMS5316 setup question
KRixon
I currently have multiple WNDAP350 devices being managed accross my network. Currently they are being used so that company wireless devices can access the network.
I am trying to find a way to also have a guest wireless network for visitors and staff which will be able to access the internet but not the internal network.
I understand that this would be possible using separate SSIDs that are on different VLANs then setting up DHCP differently for each of the VLANS. Where I am getting confused with is how to set this up as the 'DHCP settings on the WMS controller seem to indicate wanting a separate WMS controller for each of the VLANs.
Is it possible to set up network separation based on SSIDs that are being broadcast from the same access point?
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 13746 views
  • 0 kudos
  • 1 in conversation
Announcements
