Reply
WNDAP350 wired to ADSL modem router
gregaryb
Luminary
I have various laptops and PCs connected to my ADSL modem router forming a local network.
I have a WNDAP350 wired to the ADSL modem router to extend the wifi range.
However if I wifi connect to the WNDAP350, I cannot see the other computers and PCs connected to the ADSL modem router.
Is it possible to make the WNDAP350 a simple repeater for my ADSL modem router rather than a seperate access point?
If so how do you do you do this in the settings?
Model: WNDAP350|ProSafe Wireless-N Access Point
Message 1 of 2
JohnC_V
NETGEAR Moderator
Re: WNDAP350 wired to ADSL modem router
Hi gregaryb,
Welcome to our community! 🙂
There is a feature that we call Client Isolation. This option, when enabled, blocks communication between wireless clients that are associated with different VAPs.
Under the Configuration tab, select Wireless > From the sidebar, select Advanced, and then select Wireless Settings > Select the 802.11b/bg/ng tab and set the Client Isolation to "Disabled".
Here is the reference manual(page70).
JohnCarloV
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 963 views
  • 0 kudos
  • 2 in conversation
Announcements
