Reply
Tutor
WNDAP360 Radiation pattern
[ Edited ]
Hello,
I need to plan the localization of multiple WNDAP360 over a 8-levels building.
In order to do my job correctyl, I need the "antenna radiation pattern" of the WNDAP360 (you know, this kind of diagram showing the geometry of where your WNDAP radiate WiFi best).
This helps choosing accurately best position and orientation of the (50) WNAP360 s.
Usually manufacturer provide this info... but this is not showed in the install guide, nor in the reference manual.
If anyone (support team) could advise where to find such information, I would be gratefull.
Thanks
Luminary
Re: WNDAP360 Radiation pattern
all the antenna come with cubby antenna is omini directional .
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Tutor
There is no chance that the WNDAP360 is an omnidirectional antenna as it is to be mounted on wall or ceiling.
I need the radiation pattern as answer. I can't rely on assumption.
Luminary
Contact support at my.netgear.com
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Tutor
I did received an answer from support, but this forum doesn't accept to download pdf files.
So I can't show it.
The pattern is not a symetric circle.
The patterne si different for 2.4GHz and 5Ghz
Prodigy
These AP's should be mounted flat on the ceiling, and not on the wall, or sitting face up on a shelf. You can email it to me and I can add it to the thread. PM me for the email address.
Tutor
Well the user manual explains at the end of chapter 2 how to mount it on celiing, wall, and desk.
I mp you to send the pdf file. This could be usefull for other engineers.
I am also working on a project with multiple WNDAP350 and WNDAP360. Could it be possible for me to have the antenna pattern for both model?
We are using Airmagnet software for planning the location of AP, and the software need antenna pattern for accurate simulation and prediction.
Thx.
Luminary
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Tutor
I did not found your e-mail adresse.
Tutor
Thx.
You can send me an e-mail at support@bluebird.pro and I will send you back the radiation pattern of 360 and 350.
Best Regards,
Discussion Stats
  • 10 replies
  • 20899 views
  • 1 kudo
  • 4 in conversation
Top Contributors
User Kudos Count
1
1
