- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WNDAP660 Internet Access Keeps Loosing Access
- Mark as New
- Bookmark
- Subscribe
- Permalink
My WAP keeps loosing access to the internet and it does it quite often; 6 times an hour, all my wireless devices loose Interment access. They all have WIFI connectivity to the WAP and maintain their local IP but can't download even a simple page like google.com. All devices hard wired to the same firewall/switch do NOT have a problem connecting to the net. I have to turn off and on the device's wireless connection to regain access but that only works for a few minutes.
To get longer lasting connectivity I have to power cycle the WNDAAP660. After a power cycle it will run for potentially a couple days before acting up. I've noticed other users have the same problem.
I have the latest firmware 3.5.20. So at this point its worthless piece of garbage that I have to pay for support for. Does anyone have any ideas before I chuck it in the garbage and never buy another netgear product again?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dear All
We have made potential fix for this kind of issue. Could you please reach us https://www.netgear.com/support/contact.aspx to get the patch image?
Thanks
Raghu
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNDAP660 Internet Access Keeps Loosing Access
Hello zappullae,
Welcome to the community!
Sorry to hear about the issue you are having with the AP. I looked up the case and it was indicated that if the issue comes back after the factory reset and firmware update the device will be replaced. I have talked to support and asked them for someone to contact you and process your RMA. The product that you have has a Complimentary NBD (Next-Business-Day) replacement, so you there should be no charge.
I hope this helps you out.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you I will contact them. I'm trying one thing right now. I set the 5G chanell to auto. It was at at chanell 11. I will let u know in a few days.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi zappullae,
That was one of the suggested steps on your previous contact with support. We'll wait for your feedback.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unfortunately that didn't fix it. So last night it was fine and fast. The first connection this morning failed again. I had to disable and reenable WIFI on the device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi zappullae,
I looked up your record and it appears that the RMA is now in place.Let us know once you received the replacement unit.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
So the replacement arrived and is up and running. I took all the defaults except for the SID and PSK. We'll see how this works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I also upgraded the firmware to 3.5.20
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi zappullae,
Sure thing! Let us know in a few days.
Happy holidays.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, that didn't take long at all. Same problem; actually worse than the original. I switched back to the orginal, will send the replacement back, and am trying with different SIDs for 2.4 and 5G as per this thread. Last chance to make this work before I recycle it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi zappullae,
Sorry to hear that. I'm suspecting it could be the last few firmware version that's causing it. Each network is different so any troubleshooting/workaround on the thread will vary. We may have to work hand in hand with engineering to see the cause of the issue.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Changing SIDs didn't work. Turning off the each radio didn't work. I'm back to the orginal device and original settings. For some unknown reason its been stable since the morning of the 24th with only 1 glitch. We will see how it holds up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi zappullae,
I'm not sure how changing SSID's would help. If it happens again, try changing the WMM settings and see if it will make it stable.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
It happened last night. This time I couldn't keep connection for longer that a few minuets. I have it unplugged and am trying my Xfinity wifi (which was previously turned off) just for kicks and giggles. Below is a sample from the WNDAP660 log file; maybe you can see something. I have the full dowload but I don't see away to attach a file here.
Dec 26 11:27:42 hostapd: wifi1vap0: STA 74:75:48:a4:16:24 WPA: group key handshake completed (RSN) Dec 26 11:27:42 hostapd: wifi0vap0: STA f4:0f:24:0b:7c:e9 WPA: group key handshake completed (RSN) Dec 26 11:27:42 hostapd: wifi0vap0: STA e0:ac:cb:ea:c9:82 WPA: group key handshake completed (RSN) Dec 26 11:27:43 hostapd: wifi1vap0: STA fc:db:b3:ca:fd:9c WPA: group key handshake completed (RSN) Dec 26 11:28:01 hostapd: wifi0vap0: STA a0:cb:fd:9d:f7:c0 IEEE 802.11: deauth msg to/from STA, reason code (3), rssi (35) Dec 26 11:28:01 hostapd: wifi0vap0: STA a0:cb:fd:9d:f7:c0 IEEE 802.11: disassociated Dec 26 11:28:01 hostapd: wifi1vap0: STA a0:cb:fd:9d:f7:c0 IEEE 802.11: associated Dec 26 11:28:01 hostapd: wifi1vap0: STA a0:cb:fd:9d:f7:c0 WPA: pairwise key handshake completed (RSN) Dec 26 11:42:36 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a IEEE 802.11: associated Dec 26 11:42:36 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a WPA: pairwise key handshake completed (RSN) Dec 26 11:43:51 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a IEEE 802.11: recvd disassoc msg from STA, reason code (8), rssi (52) Dec 26 11:43:51 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a IEEE 802.11: disassociated Dec 26 11:47:49 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a IEEE 802.11: associated Dec 26 11:47:49 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a WPA: pairwise key handshake completed (RSN) Dec 26 11:49:48 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a IEEE 802.11: recvd disassoc msg from STA, reason code (8), rssi (27) Dec 26 11:49:48 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a IEEE 802.11: disassociated Dec 26 11:57:42 hostapd: wifi1vap0: STA 58:55:ca:50:c7:2e WPA: group key handshake completed (RSN) Dec 26 11:57:42 hostapd: wifi1vap0: STA 74:75:48:a4:16:24 WPA: group key handshake completed (RSN) Dec 26 11:57:42 hostapd: wifi1vap0: STA a0:cb:fd:9d:f7:c0 WPA: group key handshake completed (RSN) Dec 26 11:57:42 hostapd: wifi0vap0: STA f4:0f:24:0b:7c:e9 WPA: group key handshake completed (RSN) Dec 26 11:57:43 hostapd: wifi1vap0: STA fc:db:b3:ca:fd:9c WPA: group key handshake completed (RSN) Dec 26 11:57:43 hostapd: wifi0vap0: STA e0:ac:cb:ea:c9:82 WPA: EAPOL-Key timeout Dec 26 11:57:45 hostapd: wifi0vap0: STA e0:ac:cb:ea:c9:82 WPA: EAPOL-Key timeout Dec 26 11:57:47 hostapd: wifi0vap0: STA e0:ac:cb:ea:c9:82 WPA: EAPOL-Key timeout Dec 26 11:57:49 hostapd: wifi0vap0: STA e0:ac:cb:ea:c9:82 WPA: EAPOL-Key timeout Dec 26 11:57:49 hostapd: wifi0vap0: WPA hostapd_wpa_auth_disconnect: authenticator requests disconnect:STA e0:ac:cb:ea:c9:82 reason 2 Dec 26 11:57:49 hostapd: wifi0vap0: STA e0:ac:cb:ea:c9:82 IEEE 802.11: deauthenticated due to local deauth request Dec 26 11:57:49 hostapd: wifi0vap0: STA e0:ac:cb:ea:c9:82 IEEE 802.11: recvd disassoc msg from STA, reason code (2), rssi (8) Dec 26 11:57:49 hostapd: wifi0vap0: STA e0:ac:cb:ea:c9:82 IEEE 802.11: disassociated Dec 26 12:13:50 hostapd: wifi1vap0: STA a0:cb:fd:9d:f7:c0 IEEE 802.11: deauth msg to/from STA, reason code (3), rssi (38) Dec 26 12:13:50 hostapd: wifi1vap0: STA a0:cb:fd:9d:f7:c0 IEEE 802.11: disassociated Dec 26 12:14:04 hostapd: wifi0vap0: STA a0:cb:fd:9d:f7:c0 IEEE 802.11: associated Dec 26 12:14:04 hostapd: wifi0vap0: STA a0:cb:fd:9d:f7:c0 WPA: pairwise key handshake completed (RSN) Dec 26 12:15:02 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a IEEE 802.11: associated Dec 26 12:15:02 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a WPA: pairwise key handshake completed (RSN) Dec 26 12:15:31 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a IEEE 802.11: recvd disassoc msg from STA, reason code (8), rssi (51) Dec 26 12:15:31 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a IEEE 802.11: disassociated Dec 26 12:17:02 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a IEEE 802.11: associated Dec 26 12:17:02 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a WPA: pairwise key handshake completed (RSN) Dec 26 12:18:13 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a IEEE 802.11: recvd disassoc msg from STA, reason code (8), rssi (52) Dec 26 12:18:13 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a IEEE 802.11: disassociated Dec 26 12:19:25 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a IEEE 802.11: associated Dec 26 12:19:25 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a WPA: pairwise key handshake completed (RSN) Dec 26 12:19:56 hostapd: wifi0vap0: STA a0:cb:fd:9d:f7:c0 IEEE 802.11: deauth msg to/from STA, reason code (3), rssi (39) Dec 26 12:19:56 hostapd: wifi0vap0: STA a0:cb:fd:9d:f7:c0 IEEE 802.11: disassociated Dec 26 12:19:57 hostapd: wifi1vap0: STA a0:cb:fd:9d:f7:c0 IEEE 802.11: associated Dec 26 12:19:57 hostapd: wifi1vap0: STA a0:cb:fd:9d:f7:c0 WPA: pairwise key handshake completed (RSN) Dec 26 12:22:51 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a IEEE 802.11: recvd disassoc msg from STA, reason code (8), rssi (44) Dec 26 12:22:51 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a IEEE 802.11: disassociated Dec 26 12:26:11 hostapd: wifi1vap0: STA a0:cb:fd:9d:f7:c0 IEEE 802.11: deauth msg to/from STA, reason code (3), rssi (39) Dec 26 12:26:11 hostapd: wifi1vap0: STA a0:cb:fd:9d:f7:c0 IEEE 802.11: disassociated Dec 26 12:26:18 hostapd: wifi0vap0: STA a0:cb:fd:9d:f7:c0 IEEE 802.11: associated Dec 26 12:26:18 hostapd: wifi0vap0: STA a0:cb:fd:9d:f7:c0 WPA: pairwise key handshake completed (RSN) Dec 26 12:27:13 hostapd: wifi0vap0: STA 2c:10:c1:fb:fe:05 IEEE 802.11: associated Dec 26 12:27:14 hostapd: wifi0vap0: STA 2c:10:c1:fb:fe:05 WPA: pairwise key handshake completed (RSN) Dec 26 12:27:20 hostapd: wifi0vap0: STA 2c:10:c1:fb:fe:05 IEEE 802.11: recvd disassoc msg from STA, reason code (8), rssi (16) Dec 26 12:27:20 hostapd: wifi0vap0: STA 2c:10:c1:fb:fe:05 IEEE 802.11: disassociated Dec 26 12:27:42 hostapd: wifi1vap0: STA 58:55:ca:50:c7:2e WPA: group key handshake completed (RSN) Dec 26 12:27:42 hostapd: wifi0vap0: STA f4:0f:24:0b:7c:e9 WPA: group key handshake completed (RSN) Dec 26 12:27:42 hostapd: wifi0vap0: STA a0:cb:fd:9d:f7:c0 WPA: group key handshake completed (RSN) Dec 26 12:27:42 hostapd: wifi1vap0: STA 74:75:48:a4:16:24 WPA: group key handshake completed (RSN) Dec 26 12:27:42 hostapd: wifi1vap0: STA fc:db:b3:ca:fd:9c WPA: group key handshake completed (RSN) Dec 26 12:28:32 hostapd: wifi0vap0: STA a0:cb:fd:9d:f7:c0 IEEE 802.11: deauth msg to/from STA, reason code (3), rssi (44) Dec 26 12:28:32 hostapd: wifi0vap0: STA a0:cb:fd:9d:f7:c0 IEEE 802.11: disassociated Dec 26 12:28:32 hostapd: wifi1vap0: STA a0:cb:fd:9d:f7:c0 IEEE 802.11: associated Dec 26 12:28:32 hostapd: wifi1vap0: STA a0:cb:fd:9d:f7:c0 WPA: pairwise key handshake completed (RSN) Dec 26 12:31:54 hostapd: wifi1vap0: STA e0:ac:cb:ea:c9:82 IEEE 802.11: associated Dec 26 12:31:54 hostapd: wifi1vap0: STA e0:ac:cb:ea:c9:82 WPA: pairwise key handshake completed (RSN) Dec 26 12:36:32 hostapd: wifi1vap0: STA e0:ac:cb:ea:c9:82 IEEE 802.11: recvd disassoc msg from STA, reason code (8), rssi (30) Dec 26 12:36:32 hostapd: wifi1vap0: STA e0:ac:cb:ea:c9:82 IEEE 802.11: disassociated Dec 26 12:36:32 hostapd: wifi0vap0: STA e0:ac:cb:ea:c9:82 IEEE 802.11: associated Dec 26 12:36:32 hostapd: wifi0vap0: STA e0:ac:cb:ea:c9:82 WPA: pairwise key handshake completed (RSN) Dec 26 12:37:54 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a IEEE 802.11: associated Dec 26 12:37:54 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a WPA: pairwise key handshake completed (RSN) Dec 26 12:38:16 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a IEEE 802.11: recvd disassoc msg from STA, reason code (8), rssi (40) Dec 26 12:38:16 hostapd: wifi0vap0: STA 14:10:9f:c9:f1:2a IEEE 802.11: disassociated Dec 26 12:41:02 hostapd: wifi1vap0: STA a0:cb:fd:9d:f7:c0 IEEE 802.11: deauth msg to/from STA, reason code (3), rssi (37) Dec 26 12:41:02 hostapd: wifi1vap0: STA a0:cb:fd:9d:f7:c0 IEEE 802.11: disassociated Dec 26 12:41:11 hostapd: wifi0vap0: STA a0:cb:fd:9d:f7:c0 IEEE 802.11: associated Dec 26 12:41:11 hostapd: wifi0vap0: STA a0:cb:fd:9d:f7:c0 WPA: pairwise key handshake completed (RSN)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update: I've been running of the WIFI provided by Xfinity onthe same devices and have not had a single connection issue. So I am concluding this is a problem soley with the WNDAP660. Are there any items to try before I chuck the device in the trash can?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi zappullae,
At this point, it is best to contact out support team for further investigation. There is a chance that it might even need the assistance of our engineering team.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
They called me today John. I'm going to send them the log file once I recive the case # email.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi zappullae,
Alright, please keep us updated. 🙂
Happy New Year!
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
So far no one has contacted me to resolve
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi zappullae,
Sorry to hear that, I'll look up up your case and PM you the case number.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi zappullae,
You may have the same issue I have been suffering from. Please read this article. It may help.
Regards
David
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi David, that sounds like what is happening to me. I will try the solution as a last ditch effort.
- Mark as New
- Bookmark
- Subscribe
- Permalink
And I have an S6. I can't say for sure but the problem may have started when I got the phone.
