- Iscriversi a feed RSS
- Contrassegnare la discussione come nuova
- Contrassegnare la discussione come letta
- Sposta questo Discussione per l'utente corrente
- Preferito
- Iscriversi
- Pagina in versione di stampa
WNDAP660 bloccato dopo aggiornamento firmware
- Contrassegnare come Nuovo
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Segnalare contenuto inappropriato
Buongiorno, l' aggiornamento del firmware su WNDAP660 non è andato a buon fine, al riavvio si blocca,
E' possibile caricare il firmware tramite cavo seriale da U-boot ?
Grazie in anticipo per la risposta
U-Boot 2009.08-wndap660_620 (Sep 03 2012 - 11:57:28)
CPU: AMCC PowerPC APM82181 Rev. E at 1000 MHz (PLB=166, OPB=83, EBC=83 MHz)
Security support
Bootstrap Option H - Boot ROM Location I2C (Addr 0x52), booting from NAND
32 kB I-Cache 32 kB D-Cache
Board: WNDAP 660 , PCIE0/Wireless
I2C: ready
DRAM: 256 MB
NAND: 32 MiB
Configure Max Payload 256B
PCIE0: successfully set as root-complex
03 00 168c 0030 0280 ff
02 02 111d 8039 0604 00
04 00 168c 0030 0280 ff
02 03 111d 8039 0604 00
01 00 111d 8039 0604 00
Net: RTL8367RB initialize...
Disable VLAN...done
Done
ppc_4xx_eth0
Type run flash_nfs to mount root filesystem over NFS
Hit any key to stop autoboot: 0
NAND read: device 0 offset 0x110000, size 0x600000
6291456 bytes read: OK
NAND read: device 0 offset 0x1bd0000, size 0x10000
65536 bytes read: OK
## Booting kernel from Legacy Image at 00600000 ...
Image Name: Linux-2.6.36.2-wndap660_620-WNDA
Image Type: PowerPC Linux Kernel Image (gzip compressed)
Data Size: 2750072 Bytes = 2.6 MB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 01000000
Booting using the fdt blob at 0x1000000
Uncompressing Kernel Image ... OK
Loading Device Tree to 00ffa000, end 00fff881 ... OK
Using PowerPC 44x Platform machine description
Linux version 2.6.36.2-wndap660_620-WNDAP660_V3.7.4.0 (root@cbuap-build2.netgear.com) (gcc version 4.3.4 (Buildroot 2010.02) ) #1 Tue Aug 8 08:49:34 PDT 2017
Zone PFN ranges:
DMA 0x00000000 -> 0x00001000
Normal empty
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0x00000000 -> 0x00001000
MMU: Allocated 1088 bytes of context maps for 255 contexts
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 4094
Kernel command line: root=/dev/mtdblock4 rw rootfstype=jffs2 ip=192.168.1.50:192.168.1.10:192.168.1.1:255.255.255.0::eth0:off panic=1 console=ttyS0,9600 init=/linuxrc raid=noautodetect
PID hash table entries: 1024 (order: -4, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 1, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 0, 65536 bytes)
Memory: 254848k/262144k available (5504k kernel code, 7296k reserved, 448k data, 742k bss, 320k init)
Kernel virtual memory layout:
* 0xfffd0000..0xffff0000 : fixmap
* 0xfd600000..0xfe000000 : consistent mem
* 0xfd600000..0xfd600000 : early ioremap
* 0xd1000000..0xfd600000 : vmalloc & ioremap
Hierarchical RCU implementation.
RCU-based detection of stalled CPUs is disabled.
Verbose stalled-CPUs detection is disabled.
NR_IRQS:512
UIC0 (32 IRQ sources) at DCR 0xc0
UIC1 (32 IRQ sources) at DCR 0xd0
UIC2 (32 IRQ sources) at DCR 0xe0
UIC3 (32 IRQ sources) at DCR 0xf0
clocksource: timebase mult[400000] shift[22] registered
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 8192
NET: Registered protocol family 16
OCM1: 32768 Bytes (enabled)
OCM1: 32768 Bytes (non-cached)
OCM1: 0 Bytes (cached)
256k L2-cache enabled
PCIE0: Checking link...
PCIE0: Device detected, waiting for link...
PCIE0: link is up !
PCI host bridge /plb/pciex@d00000000 (primary) ranges:
MEM 0x0000000e00000000..0x0000000e7fffffff -> 0x0000000080000000
MEM 0x0000000f00000000..0x0000000f000fffff -> 0x0000000000000000
IO 0x0000000f80000000..0x0000000f8000ffff -> 0x0000000000000000
Removing ISA hole at 0x0000000f00000000
4xx PCI DMA offset set to 0x00000000
/plb/pciex@d00000000: Legacy ISA memory support enabled
Max pay load supported =0x8021 max pay load prog 0x90000
hose->first_busno = 40, hose= c8058820
PCI: Probing PCI hardware
PCI: Hiding 4xx host bridge resources 0000:40:00.0
pci 0000:40:00.0: PCI bridge to [bus 41-7f]
pci 0000:41:00.0: PCI bridge to [bus 42-ff]
pci 0000:42:02.0: PCI bridge to [bus 43-ff]
pci 0000:42:03.0: PCI bridge to [bus 44-ff]
pci 0000:40:00.0: BAR 8: assigned [mem 0xe00000000-0xe001fffff]
pci 0000:40:00.0: BAR 9: assigned [mem 0xe00200000-0xe003fffff pref]
pci 0000:41:00.0: BAR 8: assigned [mem 0xe00000000-0xe001fffff]
pci 0000:41:00.0: BAR 9: assigned [mem 0xe00200000-0xe003fffff pref]
pci 0000:42:02.0: BAR 8: assigned [mem 0xe00000000-0xe000fffff]
pci 0000:42:02.0: BAR 9: assigned [mem 0xe00200000-0xe002fffff pref]
pci 0000:42:03.0: BAR 8: assigned [mem 0xe00100000-0xe001fffff]
pci 0000:42:03.0: BAR 9: assigned [mem 0xe00300000-0xe003fffff pref]
pci 0000:43:00.0: BAR 0: assigned [mem 0xe00000000-0xe0001ffff 64bit]
pci 0000:43:00.0: BAR 0: set to [mem 0xe00000000-0xe0001ffff 64bit] (PCI address [0x80000000-0x8001ffff]
pci 0000:43:00.0: BAR 6: assigned [mem 0xe00200000-0xe0020ffff pref]
pci 0000:42:02.0: PCI bridge to [bus 43-43]
pci 0000:42:02.0: bridge window [io disabled]
pci 0000:42:02.0: bridge window [mem 0xe00000000-0xe000fffff]
pci 0000:42:02.0: bridge window [mem 0xe00200000-0xe002fffff pref]
pci 0000:44:00.0: BAR 0: assigned [mem 0xe00100000-0xe0011ffff 64bit]
pci 0000:44:00.0: BAR 0: set to [mem 0xe00100000-0xe0011ffff 64bit] (PCI address [0x80100000-0x8011ffff]
pci 0000:44:00.0: BAR 6: assigned [mem 0xe00300000-0xe0030ffff pref]
pci 0000:42:03.0: PCI bridge to [bus 44-44]
pci 0000:42:03.0: bridge window [io disabled]
pci 0000:42:03.0: bridge window [mem 0xe00100000-0xe001fffff]
pci 0000:42:03.0: bridge window [mem 0xe00300000-0xe003fffff pref]
pci 0000:41:00.0: PCI bridge to [bus 42-44]
pci 0000:41:00.0: bridge window [io disabled]
pci 0000:41:00.0: bridge window [mem 0xe00000000-0xe001fffff]
pci 0000:41:00.0: bridge window [mem 0xe00200000-0xe003fffff pref]
pci 0000:40:00.0: bridge window [io disabled]
pci 0000:40:00.0: bridge window [mem 0xe00000000-0xe001fffff]
pci 0000:40:00.0: bridge window [mem 0xe00200000-0xe003fffff pref]
CPM0: pm-iic-device resource /plb/opb/i2c@ef600700
CPM0: pm-emac-device resource /plb/opb/ethernet@ef600c00
CPM0: pm-monitor-event property not defined
CPM0: DCR at 0x160
CPM: ocm suspend address 0xd1040000
CPM: ocm resume address 0xd1040400
CPM: ocm data address 0xd10407d0
bio: create slab <bio-0> at 0
SCSI subsystem initialized
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource timebase
NET: Registered protocol family 2
IP route cache hash table entries: 16384 (order: 0, 65536 bytes)
TCP established hash table entries: 8192 (order: 0, 65536 bytes)
TCP bind hash table entries: 8192 (order: -1, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 4096 (order: 0, 65536 bytes)
UDP-Lite hash table entries: 4096 (order: 0, 65536 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
setting trigger mode 3 for irq 39 failed (uic_set_irq_type+0x0/0x23c)
kcpm: can't read pm-monitor-app
kcpm: unable to parse device tree; aborting
squashfs: version 4.0 (2009/01/31) Phillip Lougher
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
NTFS driver 2.1.29 [Flags: R/O].
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.15)
msgmni has been set to 496
Cryptodev Interface Loaded
User space CryptoAPI driver v0.1 loaded
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Generic non-volatile memory driver v1.1
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0x4ef600300 (irq = 21) is a U6_16550A
console [ttyS0] enabled
4ef600300.serial: ttyS0 at MMIO 0x4ef600300 (irq = 21) is a 16550
brd: module loaded
NAND device: Manufacturer ID: 0xad, Chip ID: 0x75 (Hynix NAND 32MiB 3,3V 8-bit)
Scanning device for bad blocks
Creating 8 MTD partitions on "4e4000000.ndfc.nand":
0x000000000000-0x000002000000 : "NAND 32MiB 3,3V 8-bit"
0x000000000000-0x000000100000 : "u-boot"
0x000000100000-0x000000110000 : "u-boot env"
0x000000110000-0x000000710000 : "kernel"
0x000000710000-0x000001bd0000 : "rootfs"
0x000001bd0000-0x000001be0000 : "Device tree"
0x000001be0000-0x000001fe0000 : "var"
0x000001fe0000-0x000002000000 : "Manu data"
PPC 4xx OCP EMAC driver, version 3.54
mal0: descriptor-memory = ocm
MAL: Enabled Interrupt Coal TxCnt: 32 RxCnt: 8
TxTimer: 100000 RxTimer: 5000
MAL v2 /plb/mcmal, 1 TX channels, 1 RX channels
RGMII /plb/opb/emac-rgmii@ef601500 initialized with MDIO support
TAH /plb/opb/emac-tah@ef601350 initialized
/plb/opb/emac-rgmii@ef601500: input 0 in RGMII mode
PHY ID: 0xffffff87
RTL8363SB initialize...
Done
eth0: EMAC-0 /plb/opb/ethernet@ef600c00, MAC 84:1b:5e:5e:27:78
eth0: found Realtek 8363SB Ethernet Switch PHY (0x00)
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
i2c /dev entries driver
of:ibm-iic 4ef600700.i2c: using standard (100 kHz) mode
of:ibm-iic 4ef600800.i2c: using standard (100 kHz) mode
AMCC 4xx PKA v0.1 @0x04_00114000 size 16384 IRQ 22
Initializing PKA...
PKA Driver Successfully Initialized
oprofile: using timer interrupt.
GACT probability on
Mirror/redirect action on
Simple TC action Loaded
netem: version 1.2
u32 classifier
Performance counters on
input device check on
Actions configured
Netfilter messages via NETLINK v0.30.
TCP cubic registered
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 17
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
lib80211: common routines for IEEE802.11 drivers
Registering the dns_resolver key type
eth0: link is up, 1000 FDX, pause enabled
IP-Config: Complete:
device=eth0, addr=192.168.1.50, mask=255.255.255.0, gw=192.168.1.1,
host=192.168.1.50, domain=, nis-domain=(none),
bootserver=192.168.1.10, rootserver=192.168.1.10, rootpath=
VFS: Mounted root (jffs2 filesystem) on device 31:4.
Freeing unused kernel memory: 320k init
Wed Jun 1 00:00:00 UTC 2016
Mounting etc to ramfs. [DONE]
Mounting var to jffs2. rootfs on / type rootfs (rw)
/dev/root on / type jffs2 (rw,relatime)
proc on /proc type proc (rw,relatime)
tmpfs on /tmp type tmpfs (rw,relatime)
devpts on /dev/pts type devpts (rw,relatime,mode=620)
none on /etc type tmpfs (rw,relatime)
[DONE]
Checking SSH keys. [DONE]
Checking for run file. [DONE]
Starting System Logger. [DONE]
Starting Kernel Logger. [DONE]
USAGES: /usr/bin/wr_mfg_data -h for Help.
Checking Manufac. data [DONE]
Checking board file. [CREATED]
Loading Ethernet module. [DONE]
Checking database. [DONE]
Verifing checksum. [DONE]
Loading Bridge module. sh: yes: unknown operand
[DONE]
Loading wlan modules. Oops: Machine check, sig: 7 [#1]
last sysfs file:
Modules linked in: umac(+) ath_dev(P) ath_rate_atheros(P) ath_dfs(P) ath_hal(P) adf asf(P) band_steering(P) bridge stp llc activity_led(P) proc_gpio
**bleep**: c0012d8c LR: d59802e8 CTR: 00000088
REGS: cfff7f10 TRAP: 0214 Tainted: P (2.6.36.2-wndap660_620-WNDAP660_V3.7.4.0)
MSR: 00029000 <EE,ME,CE> CR: 24000042 XER: 20000000
TASK = c8296e10[454] 'insmod' THREAD: c826a000
GPR00: 00000000 c826b9c0 c8296e10 ca8e7f08 d5f82004 00000440 ca8e7f04 00000000
GPR08: 00000000 ca8f0000 00003fff c0012d68 44000022 101044a8 c826be74 c04ba1d4
GPR16: 0000fff2 0000fff1 d5a1eb60 c826bb20 00000001 ca8e0000 d5a19bd8 d5a29bd8
GPR24: ca8decd0 c826bc18 c8663a40 d5a40000 00000440 ca8e7f08 ca8e0000 d5a38e84
**bleep** [c0012d8c] memcpy+0x24/0x9c
LR [d59802e8] ath_hal_memcpy+0x18/0x30 [ath_hal]
Call Trace:
[c826b9c0] [c826bc18] 0xc826bc18 (unreliable)
[c826b9e0] [d59d0ac8] ar9300EepromRestoreInternal+0x2b8/0x2fc [ath_hal]
[c826ba00] [d59d0b50] ar9300EepromRestore+0x44/0x9c [ath_hal]
[c826ba20] [d59d0bf8] ar9300EepromAttach+0x50/0xfc [ath_hal]
[c826ba30] [d59cab94] ar9300Attach+0xe48/0x1634 [ath_hal]
[c826bae0] [d598288c] ath_hal_attach+0x1e8/0x20c [ath_hal]
[c826bb10] [d5980544] _ath_hal_attach+0x48/0x64 [ath_hal]
[c826bb40] [d5c5f5f4] ath_dev_attach+0x11c/0x1598 [ath_dev]
[c826bbc0] [d5dea39c] ath_attach+0xa4/0xda4 [umac]
[c826bc10] [d5e25328] __ath_attach+0x140/0x330 [umac]
[c826bc90] [d5e25bd8] ath_pci_probe+0x200/0x3ec [umac]
[c826bce0] [c01f278c] local_pci_probe+0x24/0x34
[c826bcf0] [c01f3158] pci_device_probe+0x84/0xa8
[c826bd20] [c0219614] driver_probe_device+0x88/0x1a0
[c826bd40] [c02197e8] __driver_attach+0xbc/0xc0
[c826bd60] [c0218cf8] bus_for_each_dev+0x70/0xac
[c826bd90] [c0219438] driver_attach+0x24/0x34
[c826bda0] [c0218478] bus_add_driver+0xb4/0x278
[c826bdd0] [c0219b58] driver_register+0x80/0x170
[c826bdf0] [c01f33d4] __pci_register_driver+0x4c/0xdc
[c826be10] [d5e90050] init_ath_pci+0x50/0xd0 [umac]
[c826be20] [c0001474] do_one_initcall+0x34/0x1b8
[c826be50] [c0058144] sys_init_module+0xf0/0x16c8
[c826bf40] [c000ca20] ret_from_syscall+0x0/0x3c
--- Exception: c01 at 0x480aaca8
LR = 0x10013568
Instruction dump:
4e800020 7c032040 418100a0 54a7e8ff 38c3fffc 3884fffc 41820028 70c00003
7ce903a6 40820054 80e40004 85040008 <90e60004> 95060008 4200fff0 70a50007
---[ end trace 60fdba2fe0dd8104 ]---
eth0: no IPv6 routers present
- Preferito
- Iscriversi
- Evidenziare
- Stampare
