Reply
Wd930 issue
Timmeke
Wd930 issue
I have wd930 issue.
After correct installation I connected my laptop with utp for configuration. After typing the correct IP address for wd930. I get the login screen. After entering admin as username and password as password itself, i get an error that Ip adress is not reacting anymore. After that I can not get into the login screen anymore by refreshing the browser. After resetting the access point, i get login screen again but again same problemmm.
I tried different browser types: explorer and chrome
I tried also other pc
Access point is new from box and the unprotected wifi is working perfectly on the acces point
What can be the issue???
Message 1 of 8
Accepted Solutions
Re: Wd930 issue
@Timmeke wrote:
After correct installation ...
Possibly.
In that case you can open a support case with Netgear. Support is free for the first 90 days after purchase.
Then again, the WN930, which, as @FURRYe38 suggests, this may be, dates back five years or more.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 8 of 8
All Replies
Guru
Re: Wd930 issue
Is this a NG product? That model doesn't ring up...
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CBR750 Modem | Wifi Router CBR750(v.7) | Switches NG GS105/8 and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 2 of 8
Timmeke
Re: Wd930 issue
To be complete:
After the login i also got the screen for changing current password, after clicking on change password the Ip gets lost each time and nothing appears anymore on the screen, only fact that IP address doesnt react anymore.
Message 3 of 8
Guru
Re: Wd930 issue
Message 4 of 8
Timmeke
Re: Wd930 issue
Wnd 930 outdoor dual band access point
Message 5 of 8
Guru
Re: Wd930 issue
I see:
https://www.netgear.com/business/wifi/access-points/wnd930/
Message 6 of 8
Re: Wd930 issue
@FURRYe38 wrote:
I see:
Crikey. Good bit of research there.
An old bit of Netgear stuff from a long abandoned range.
Usual boilerplate replies.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Business Wireless - NETGEAR Communities
Just another user.
Message 7 of 8
Re: Wd930 issue
Possibly.
Just another user.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 316 views
  • 0 kudos
  • 3 in conversation
Announcements
