Reply
Wifi trunk (before sale question)
dabacertia
Hello,
Is it possible to establish a wifi trunk of this kind (A or B)?
A.
+ AP in client mode receives different SSIDs and tag them on the nic
- Advantage: the AP that "send signal" can send signal to "normal" clients (computers, smartphones, printer...) and the APs in client mode.
- Advantage: no need to have a dedicated wifi bridge infrastructure
- Need: a specific client mode
B.
+ AP in client mode receive one SSID dedicated to trunk and the "sender AP" sends several SSIDs to normal clients and on SSID dedicated to the wifi trunk
- Need: a specific client mode + a specific "wifi trunk" on "sender" side
Thanks for your ideas/informations/solutions
Message 1 of 7
Accepted Solutions
JohnC_V
NETGEAR Moderator
Re: Wifi trunk (before sale question)
Hi dabacertia,
Welcome to our community!
It is easier to use the first option that you have. You just need to set the port on trunk where the AP is connected so that it can also broadcast the other VLANs. It will still be depending on the AP you are going to use if it supports VLAN.
Message 3 of 7
All Replies
dabacertia
... the B visio in attach
Message 2 of 7
JohnC_V
NETGEAR Moderator
Hi dabacertia,
Message 3 of 7
dabacertia
Hello John,
Thanks for your answer, I will give it a try. I don't know why I thought it needed special feature to transport a trunk through an wireless network/SSID. It is so simple I did not tried it.
Have a nice day
Message 4 of 7
JohnC_V
NETGEAR Moderator
dabacertia,
Setting up a Trunk to the AP is only applied if you do have multiple SSIDs. If none, no need to configure trunk on it.
Message 5 of 7
dabacertia
Thanks! (a lot) I took good note.
Message 6 of 7
JohnC_V
NETGEAR Moderator
dabacertia,
I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2502 views
  • 2 kudos
  • 2 in conversation
Announcements
