Reply
Wireless Controller 7500 upgrade to 6.5.5.18 from 6.0.1.0
Murrayfield
Tutor
Hi,
Apologies if this has been raised elsewhere but I couldnt find a relevant issue identical to mine.
I am remote from the office where my WC7500 exists.
I remoted on to a PC on the appropriate network, backed up the exisitnf 6.0.1.0 firmware and kicked off the upgrade process to 6.5.5.18.
I have none of the listed WACs in my network so went straight to the biggie.
Took a while then came back with the following message
Site cant provide a secure connection
Site 192.168.x.x uses an unsupported protocol
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
the Client or server dont support a common SSL protocol version or cipher suite.
Now I guess this means I have to drop an appropriate cerificate onto my PC which I am trying to login with but where do I pick one up?
Any advice appreciated, I went into the office the other day and thankfully the controller is still working, but I dont want to reboot it in case I have problems getting it to recognise WAPs again
Message 1 of 3
Accepted Solutions
Murrayfield
Tutor
Re: Wireless Controller 7500 upgrade to 6.5.5.18 from 6.0.1.0
Hi
Thanks for that, it worked in Firefox, I will just have to remember for future reference
Cheers
Ian
Message 3 of 3
All Replies
schumaku
Guru
Edge in IE mode should work.  There is a setting in FireFox to allow TLS 1.0 connections.
Message 2 of 3
Murrayfield
Tutor
Hi
Cheers
Ian
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1054 views
  • 0 kudos
  • 2 in conversation
Announcements
