Reply
can I add a 2nd satellite to my existing SRR60
Skillings
Follower
I bought an SRR60 Orbi Mess network I would like to add a second sateliite onto the orginal system I have the Orbi Pro Router SRR60 with one satelitte?  Which model should I order?
Thank you
Don
Message 1 of 3
Guru
Re: can I add a 2nd satellite to my existing SRR60
The SRS60 is the satellite.
The SRR60 is the router.
So you'd want the SRS60
Message 2 of 3
schumaku
Guru
The SRC60 — Orbi Pro AC3000 WiFi 5 Tri-band Add-on Ceiling Satellite is also workable with the Orbi Pro system - and typically better suited to work for ceiling or wall mount.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1331 views
  • 0 kudos
  • 3 in conversation
Announcements
