Reply
upgrade WNDAP660 firmware 2.0.2 to, V2.0.5
rmumm2
after firmware upgrade, all tabs are missing exept configuration?
I cannot upgrade to next level as tabs are missing.
factory reset attempted twice, failed, still have configuration befoire firmware upgrade.
any ideas appreciated.
Thanks
Model: WNDAP660|ProSafe 3x3 Dual Radio Dual Band Wireless-N Access Point
Message 1 of 4
DaneA
NETGEAR Moderator
Re: upgrade WNDAP660 firmware 2.0.2 to, V2.0.5
Hi @rmumm2,
Welcome to the community! 🙂
As far as I checked, there is no issue on the WNDAP660 as per you have described in your initial post.  Let us isolate the problem.  Kindly answer the questions below:
a. What is the behavior of the LED lights of the WNDAP660?
b. Clear the cache of the browser you are using.  Then, access again the web-GUI of the WNDAP660.  Does the same problem occur?
c. Use other browsers like Firefox or IE9.  Then, access again the web-GUI of the WNDAP660.  Does the same problem occur?
d. Use other PC or laptop then access again the web-GUI of the WNDAP660.  Does the same problem occur?
Kindly upload a screenshot or image of what you see or if there is an error message you have encountered if ever the same problem occurred.
DaneA
NETGEAR Community Team
Message 2 of 4
DaneA
NETGEAR Moderator
@rmumm2,
I just want to follow-up on this.  We’d greatly appreciate your feedback.
DaneA
Message 3 of 4
rmumm2
I returned the device as i could not get resolve and purchased a new unit, works great.
Thank you for your support.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1360 views
  • 0 kudos
  • 2 in conversation
Announcements
