Reply
wndap660 two lans?
craigpat93
wndap660 two lans?
I have recently purchased a wndap660 which says it is multiple input multiple output.
it has two lan ports, i was hoping i could run two Lans via different wifi networks.
is this achievable? if so could someone point me in the right direction to do this as i cannot seem to find those options to assign networks to certain lan
thanks!
Model: WNDAP660|ProSafe 3x3 Dual Radio Dual Band Wireless-N Access Point
Message 1 of 6
Guru
Re: wndap660 two lans?
I would review the online user manual information regarding this to see if this is supported.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 6
craigpat93
hey,
 I did, and I couldn't see a lot about the reason for it having 2 lan ports.
it just says all can be used to connect. dont know if its to use to send back out to wired devices, as a backup, or for second networks.
thats why I've come to here 🙂
Message 3 of 6
Guru
I don't have one of these though sometimes having a extra LAN port on the back just means you can connect up an extra device like a PC or laptop or probably daisy chain these with another AP down the line if they were to be ethernet connected. If you don't see any references to separate networks or dual lans, then probably something that's not supported.
Message 4 of 6
Guru
thanks!
The multiple input/mulitple output (mimo) is a wireless spec to increase throughput.
https://en.wikipedia.org/wiki/MIMO
Not for connecting to different wireless networks and assigning them to different lans.
what you're trying to accomplish isn't possible with that device.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 5 of 6
thanks!
A section given over to General WiFi Routers is probably not the best place for deep details on this ProSAFE® Business 2 x 2 Dual Band Wireless-AC Access Point.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Business Wireless - NETGEAR Communities
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 5506 views
  • 0 kudos
  • 4 in conversation
Announcements
