- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC 1750 WIFI not broadcasting
- Mark as New
- Bookmark
- Subscribe
- Permalink
My router just quit broadcasting WiFi, I have reset and restarted multiple times with no luck. Power, upstream, down stream and internet lights all green. No other lights are on. Pushing and holding wifi on/off swithch does nothing.
My laptop does not have a network port and I can't connect using WiFi. How can I connect to the router without a network cable or Wifi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC 1750 WIFI not broadcasting
Try pressing the reset button in back for 15 seconds then release then setup from scratch with a wired PC and web browser?
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
- Mark as New
- Bookmark
- Subscribe
- Permalink
AC1750 is a speed, not a model. what actual model do you have?
did you push and hold the wifi on/off button for at least 2 seconds.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Router C6300: WIFI not broadcasting
The main problem is connecting my laptop to the router. My laptop does not have a network port. USB only.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Router C6300: WIFI not broadcasting
You can buy a USB device that creates a wired LAN port.
As seen on Amazon, its costs around $£€10. There are many more like it.
Always worth having around.
Disclaimer: Just another user with time on their hands.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
