Orbi WiFi 7 RBE973
Reply
AC1900 C7000V2 power light red
jcabal
I had a brief power outage last night and now the modem/router will not power up. Power light is red, and I have unplugged from outlet, waited a couple of minutes and plugged back in, but no change. Does this mean the device is "fried" and needs to be replaced? Any help would be greatly appreciated.
Message 1 of 5
Guru
Re: AC1900 C7000V2 power light red
could be.
what you can try.
disconnect the coax from the c7000. Then while the c7000 is powered on, push and hold reset for 30 seconds, unplug power while still holding reset for another 30 seconds, then power it back on while still holding reset for 30 seconds.
Message 2 of 5
jcabal
Just tried that, but unfortunately no change. Thank you for responding, though.
Message 3 of 5
Guru
it could be bad. another thing you can try is contact your isp and see if they can ping/re-provision it.
Always worth a chance
Message 4 of 5
Guru
If so, your isp will need to check the line
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2960 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
