- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC1900 - Model C7000v2 Router will give laptops internet access but not mobile devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
yesterday, we had a power outage. When power came back on, laptops reconnected to the router. The phones - an iPhone and an Android - can't connect to the internet. I disconnected ("forget") on the android. When I reconnected, after reconnnecting, it won't connect to the internet. If I wait, it says "tap here to connect" and brings me to routerlogin.com - the admin account settings page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1900 - Model C7000v2 Router will give laptops internet access but not mobile devices
have you tried simply factory resetting the router and reinstalling it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I did that and nothing improved.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried changing the wifi ssid and password to something new?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Found out that the issues went beyond my phones. Couldn't connect to certain websites, access my email with Outlook, and use certain apps - like Teams.
Reset again through Xfinity, but no luck with that.
Hauled out the orginal modem router, and that is working fine. (File under "Why are you keeping the old router?"
I appreciate you taking the time to respond. Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
For iPhones did you turn OFF "WiFI Private Address" feature on the phone?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for the input. I ended up replacing the router as other apps stopped working.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be aware that Apples new WiFi Privacy Address feature is causing some problems. Something you can disable while at home. If you travel, enable it then.
Good Luck.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
