Orbi WiFi 7 RBE973
Reply
AC3200 connection to a Tekwave Modem
honeycutt0914
Follower
Hi Everyone!
I purchased a Nighthawk X4S C7800v2 for my previous home when we had Sparklight GigaOne service since we are heavy gamers and streamers. We have since moved and are working with Tekwave satelite internet until we recieve our Starlink services. I was told by the installer that I could connect my Nighthawk to their modem to boost the signal strength and distance. The only connection I can use to it is via the ethernet cable but am having trouble figuring out how to make this work. Has anyone been able to accomplish this?
Thanks for the help!
Model: C7800|Nighthawk X4S-AC3200 WiFi Cable Modem Router
Message 1 of 2
Guru
Re: AC3200 connection to a Tekwave Modem
The C series mode requires a Coax cable line in service thus from a Cable ISP service. If your new ISP already has a specific modem for use on there service and I presume required for there services, then the C series modem can't be used.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBE973S and SXK30; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 254 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
