- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C3000-100NAS Hard Drive not recognized
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've previously used an external IDE USB Disk housing for NAS with the C3000 and it worked OK until the drive died. I had to get a new housing due to changing to SATA drive. The C3000 would not recognize (NO USB DRIVE) the new drive/housing - rebooted the C3000, no help, rebooted the PC (Windows 10 ver. 1903), no help. The new housing has power-saver (auto-off) but I was able to click on the "refresh" Button in Genie several times with the drive running, no help. Tried a different drive, no help. Drives are Seagate ST1000DM010 and WD FDB1002FBYS, both have previously been used as internal drives and worked fine. I suspected the one new component, the USB housing, so I unplugged the USB cable from the modem and plugged it into the PC's USB port = worked great, NO problem, WITH the same USB housing (except that the PC doesn't let it sleep). Disks are freshly formatted with NTFS in the same PC, no MBR. Help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C3000-100NAS Hard Drive not recognized
Was the old USB case USB 1.0 or 2.0? Is the new USB case USB 3.0?
Some USB 3.0 may not be backwards compatible.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:Was the old USB case USB 1.0 or 2.0? Is the new USB case USB 3.0?
I believe the old case was 2.0 (maybe not high speed 2.0); the new one is 3.0. I used the same USB cable (2.0) as I only expected 2.0 speed - and the power is separtate. It is possible that the unit is not downward compatible - I cannot get that answer from Amazon or the vendor - although I thought sownward compatibility was part of the standard. Even on the old case, I had to power-cycle the modem top get it to find the external HDD.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Probably the new USB 3.0 case is not compatbile with the modem.
You can't use a USB 2.0 cable on a USB 3.0 device. Has to be a 3.0 USB cable. One with the blue connector plug at each end.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
