Orbi WiFi 7 RBE973
Reply
C3000 not operating as modem
jamesmmckenna
Follower
Hello, so I just purchased the R6400 router and was looking to connect it to my c3000 modem/router. I had a couple of problems. First of all, can I put the c3000 in a mode that makes it only a modem? Secondly, I keep getting an error when setting up the n6400 that it can't find the Internet connection. Does the configuration I mentioned above not work? Thanks
Message 1 of 2
TheEther
Guru
Re: C3000 not operating as modem
You can put the C3000 into modem only mode by going to ADVANCED > Aministration > Router Mode and selecting No, then Apply.
See page 73 of the manual (link).
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2459 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
