- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C3700v2 won't reset, and I don't know the twit's (my ex) access info to manage the wifi. Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is connected to a standard cable ISP. The system is a custom built, encrypted server, running Windows 10 (largely disabled) Mozilla4eThe modem part works fine, even the cabled router works fine. But the WiFi is still from that jerkoff that I should never have given a taste down below, and which is useless to me at my new flat. I know I can pay someone to cable everything by just drilling holes through walls, floors, etc., and installing a hub to handle all those cables. But seriously? What is the point in having these 65" smart oled TV's with full high speed streaming on wifi, when I don't have a usable wifi? And what about when my girlfriend and I are lounging with our iphones - can't go through our Proton VPN unless we can access the fileserver at the core. More cables for the iphones, from the bedroom? Will I need them in every bloomin room? Or should I just trash this WiFi Cable Modem Router, and buy from a more reputable company like Cisco?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C3700v2 won't reset, and I don't know the twit's (my ex) access info to manage the wifi. Any id
If you can access the gui from the browser (hardwired in based on your post) you can reset it. the option is under advanced-->administration-->backup settings and there's an erase section on there. It should reset everything back to default.
There's also the reset button on the device that you push for 7-10 seconds until the lights change on the combo device. That'll reset it as well.
have you tried these options?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also try doing a reset with the ISP Coax cable disconnected from the modem.
@Tulia wrote:This is connected to a standard cable ISP. The system is a custom built, encrypted server, running Windows 10 (largely disabled) Mozilla4eThe modem part works fine, even the cabled router works fine. But the WiFi is still from that jerkoff that I should never have given a taste down below, and which is useless to me at my new flat. I know I can pay someone to cable everything by just drilling holes through walls, floors, etc., and installing a hub to handle all those cables. But seriously? What is the point in having these 65" smart oled TV's with full high speed streaming on wifi, when I don't have a usable wifi? And what about when my girlfriend and I are lounging with our iphones - can't go through our Proton VPN unless we can access the fileserver at the core. More cables for the iphones, from the bedroom? Will I need them in every bloomin room? Or should I just trash this WiFi Cable Modem Router, and buy from a more reputable company like Cisco?
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
