Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C6220 as an access point with Xfinity Gateway
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-01-04
06:31 AM
2021-01-04
06:31 AM
Hi,
In my new home I cannot use my C6220 as the connection is fiber only (Xfinity) - I have to use their gateway. I'm trying to use C6220 as an access point now to extend wifi range a bit.
I've connected it via Ethernet, set up wifi network different from the one on the gateway, configured C6220 to have static ip address (and reserved it on the gateway), disabled dhcp and dns broadcasting on C6220.
Now I can access Internet if I connect to C6220 wifi, but there is a catch - connection stops working properly every few minutes: I can still ping everything, but I cannot connect to any port. E.g ping google.com will work, but https://google.com won't open. And the biggest mystery to me is that it all starts working again if I open C6220 web interface on that device. Note, opening the gateway web interface doesn't fix the problem.
I feel this is some sort of timeout or a security "feature", but I didn't see anything neither on C6220 not on the Xfinity gateway. Any ideas what should I look for?
Model: C6220|DOCSIS 3.0 High Speed WiFi Cable Modem Router
Message 1 of 2
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-02-23
03:28 PM
2021-02-23
03:28 PM
Re: C6220 as an access point with Xfinity Gateway
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 2
Announcements
