Orbi WiFi 7 RBE973
Reply
C6300 AC1750 add another router or access point
rehousejr
Hi,
I have a C6300 AC1750 and I wanted to hard wire another router or access point to an outside pool house so my pool area has better wifi. Can I do that and if so, how? Would any router or access point work?
Thank you!
Model: C6300|AC1750 Cable Modem Router Docsis 3.0
Message 1 of 3
Guru
Re: C6300 AC1750 add another router or access point
yes you can wire in an access point or a router that supports access point mode.
Either would work. I've used multiple routers as access point and even some of the models of extenders support access point mode.
so you have many options.
Message 2 of 3
rehousejr
Thank you very much for your input!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 574 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
