Orbi WiFi 7 RBE973
Reply
C6300 finding network security key
drlswat13
Follower
Trying to setup my new HP Laptop and it is asking for the network security key (not my network password key) which I can not find. Can someone help with this Thanks Dan
Message 1 of 2
Re: C6300 finding network security key
The term "security key" is usually used to describe the wifi password.
Tell us what you are trying to do and you might get better replies.
By the way, you have posted your message in the section of this community given over to R6000 Series AC WiFi Routers. Your devices is a Cable Modem. You might do better here:
Cable Modems & Routers - NETGEAR Communities
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1093 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
