Orbi WiFi 7 RBE973
Reply
C6300 trying to logon to wifi, says incorrect password
PamNC
Follower
Not able to logon to wireless with other devices
Model: C6300|AC1750 Cable Modem Router Docsis 3.0
Message 1 of 2
Guru
Re: C6300 trying to logon to wifi, says incorrect password
This would be your forum.
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Maybe the wif password is wrong?
You can hardwire into the the C6300 and login into the gui without needing the wifi password. From here you can change ssid and password. Or it could be that your other devices have the wrong wifi password save. Try both the resetting the wireless password as well as going into your devices, forgetting the wireless, and re-logging into it.
https://kb.netgear.com/23439/How-do-I-change-my-NETGEAR-router-s-WiFi-password-or-network-name-SSID
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 588 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
