Orbi WiFi 7 RBE973
Reply
C6300 wifi drops but ethernet works
bootsBslick79
Follower
C6300 over a year old loses wifi but ethernet ports seem to work. If I reset router/modem the wifi will work with multiple devices then after approximately 10 mins or less it's gone yet anything plugged into the ethernet works fine. HELP!!!!
Model: C6300|AC1750 Cable Modem Router Docsis 3.0
Message 1 of 2
Guru
Re: C6300 wifi drops but ethernet works
Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 396 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
