Orbi WiFi 7 RBE973
Reply
C6300v2 wired connection stopped working twice.
NightBirdWatch
Follower
Hello. I have had my C6300v2 for a few weeks, and yesterday suddenly my wired connection to the internet went out. All wireless devices could still connect fine. The light on the back of the router for that LAN port was flashing yellow.  I jiggled all the wires and power cycled everything multiple times and eventually got back online.  Then today all of sudden the same thing happens, and my wife mentions it is around the same time she happend to unplug her laptop from the wired connection and went wireless (she is on a differnet port).  Any clues as to whats going on? I have never not been able to get an IP address after plugging in a wire directly from my computer to the router, this is so frustrating.
Model: C6300|AC1750 Cable Modem Router Docsis 3.0
Message 1 of 2
Guru
Re: C6300v2 wired connection stopped working twice.
Has a factory reset and setup from scratch been performed since last update?
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 459 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
