Orbi WiFi 7 RBE973
Reply
C6900 2.4G SSID Disappeared
BKhoo
My wireless devices all of a sudden can't see the SSID of the 2.4G channel of my router.  The 5G channel is still visible.  I've had this router for probably 2 years and have been using the 2.4G channel without issue.  What may be causing this and how to resolve?  I need the 2.4G channel because i have 2 old devices that can't detect 5G.
Thanks!
Model: C6900|High Speed Cable Modem Router
Message 1 of 4
Accepted Solutions
Guru
Re: C6900 2.4G SSID Disappeared
Have you logged into the router to see if the 2.4ghz ssid broadcast was disabled?
Or even just tried a factory reset and reinstall? I'd normally tell you to reinstall the firmware but with combo devices, the isp controls the firmware.
Message 2 of 4
All Replies
Guru
Message 2 of 4
BKhoo
Resetting worked.  Thanks.
Message 3 of 4
Guru
Glad to hear you got it working! If you mark it as solved, it could help the next person
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 832 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
