Orbi WiFi 7 RBE973
Reply
C7000
Bella-1
C7000
I only get two bars right beside the modem. Why is that and how do I get more bars.
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 13
Guru
Re: C7000
what device are you testing with?
are you testing on 2.4ghz or 5ghz? 2.4ghz is more sensitive to interference.
do you live in house, apartment, condo, etc?
Message 2 of 13
Bella-1
Re: C7000
I have a house I use 5 g on my phone but my husband uses 2.4g and gets less bars.
Message 3 of 13
Guru
Re: C7000
what speeds do you get hardwired into it?
what speeds do you get over 5ghz while close to it?
and 2.4ghz?
Message 4 of 13
Bella-1
Re: C7000
Says I am getting 866 Mbps right next to it.
Message 5 of 13
Guru
Re: C7000
most phones are 2x2 antenna arrangements. Thats the max link speed you'll get out of it.
throughput is different thank link speed though.
Message 6 of 13
Bella-1
Re: C7000
Thank you.
Message 7 of 13
Re: C7000
That sounds like a connection speed rather than data throughput.
Anyone who got 866 Mbps on wifi should be delighted. It is faster than most wifi clients can handle.
Is your connection slowing you down in any way?
By the way "bars" are notoriously useless indicators of anything beyond the availability of a decent drink.
And is is two out of three or two out of ten?
Message 8 of 13
Bella-1
Re: C7000
It's fine good speed on accessing, the internet. The Mbps ranges from 450 to 650 it depends on where you are in the house but, I am very pleased with the modem.
Message 9 of 13
Re: C7000
Those speeds are good for wifi.
Did you ever tell us the speeds you get with a wired connection? That us more reliable than any wifi measurement, which depends on the wifi clients rather than the modem router.
Message 10 of 13
Bella-1
Re: C7000
I haven't checked the wire speed but it has went down now to 112 Mbps and signal is only at 57%
Message 11 of 13
mcp_57
Re: C7000
Looking for recommended range extender for 2000 s/f residential dwelling
Message 12 of 13
Guru
Re: C7000
Try the EX7000.
For any Extender question, information or help, be sure to post in the Extender forum:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Good Luck.
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 2037 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi 770 Series
