Orbi WiFi 7 RBE973
Reply
C7000v2
user113
Follower
C7000v2
My Netgear C7000v2 router needs a firmware upgrade. When I enter the Netgear app, I see a screen saying "Firmware Out Of Date." There are two buttons: the first says "Open router login.net", which takes me to a website that tells me to download the app, which i already have. The second says "Connect with anywhere access", which when clicked on, displays the following message: "No devices available. to remotely manage a netgear router, enable the feature by connecting your routers wifi and then going to menu settings anywhere access within the app." Again, my wifi is working and I have the app installed, but I can't get to settings to establish anywhere access, because all I can access within the app is the firmware out of date page. Re installing the app has not helped.
Message 1 of 2
Re: C7000v2
That is an error in the app. (I thought they had fixed it months ago.) Ignore it.
The app should not tell you to update the firmware on a cable modem because you cannot update the firmware. That is down to your ISP.
What is the latest firmware version of my NETGEAR cable modem or modem router? | Answer | NETGEAR Su...
Just another user with a set of boilerplate macros.
My network DM200 -> MK93; R7800 -> GS316 -> PL1000 -> R7000P
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 371 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
