- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C7100V Parental Contol - NetGear Gennie conflict
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Parental Contol tab in the NetGear Gennie opens an internet page directing to download Circle on Netgear App. The App however says that the C7100V is NOT a supported device, so you can't use the App to set up parental controls. You also can't set them up in the NetGear Gennie because it forces you to the internet page. Seems like someone at NetGear missed a step to install Circle in the modem. This NEEDS TO BE FIXED.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C7100V Parental Contol - NetGear Gennie conflict
You'll need to probably ignore what the app is doing. Genie is being retired and not developed on anymore. Circle isn't supported so it's recommended to manage the modem using the modems web page only.
Good Luck.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
