Orbi WiFi 7 RBE973
Reply
C7800 Keeps Disconnecting and/or Very Slow
Our C7800 Nighthawk cable modem router recently started disconnecting or getting VERY slow speeds out of the blue. We purchased it in April 2021 and it worked flawlessly up until the middle of last month. This happens while diriectly connect to the Nighthawk AND on WiFi from several different devices. I've done a factory reset, contacted the ISP (Wow! Internet) multiple times, rebooted, etc and have had no luck. Very frustrating.
The Cable Connection info changes often. One time I only had one unlocked channel, I'll refresh the cable connections page and all of a sudden ALL of the downstream channels are not locked. The ISP keeps telling me it's a hardware issue and to contact Netgear.
There's one splitter in the Coax cable and I don't have a power source where it comes into the house to directly attach the Nighthawk to it.
Do any of you have suggestions?
Cable Connection
Apply             Cancel
Frequency start Value
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
Starting Frequency
<tabindex=-1>Startup Procedure</tabindex=-1>
ProcedureStatusComment
Acquire Downstream Channel747000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityENABLEDBPI+
IP Provisioning ModeHonor MDDIPv4 only
<tabindex=-1>Downstream Bonded Channels (Partial Service)</tabindex=-1>
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectabables
1LockedQAM25631747000000 Hz-3.0 dBmV38.9 dB00
2LockedQAM2561561000000 Hz0.6 dBmV31.1 dB11668599687709
3LockedQAM2562567000000 Hz0.8 dBmV42.5 dB00
4LockedQAM2563573000000 Hz1.0 dBmV42.7 dB00
5LockedQAM2564579000000 Hz0.7 dBmV42.4 dB00
6LockedQAM2565585000000 Hz0.8 dBmV42.5 dB00
7LockedQAM2566591000000 Hz0.8 dBmV42.5 dB00
8LockedQAM2567597000000 Hz1.2 dBmV42.5 dB00
9LockedQAM2568603000000 Hz1.3 dBmV42.5 dB00
10LockedQAM2569609000000 Hz1.5 dBmV42.6 dB00
11LockedQAM25610615000000 Hz1.5 dBmV41.3 dB3450
12LockedQAM25611621000000 Hz1.5 dBmV34.6 dB316728281489
13LockedQAM25612627000000 Hz0.9 dBmV31.4 dB12029340300
14LockedQAM25613633000000 Hz0.4 dBmV41.6 dB23459041268636
15LockedQAM25614639000000 Hz0.4 dBmV41.9 dB45940
16LockedQAM25615645000000 Hz0.5 dBmV41.9 dB00
17LockedQAM25616651000000 Hz0.7 dBmV41.8 dB00
18LockedQAM25617657000000 Hz0.8 dBmV41.9 dB00
19LockedQAM25618663000000 Hz0.8 dBmV41.7 dB00
20LockedQAM25619669000000 Hz0.6 dBmV41.6 dB00
21LockedQAM25620681000000 Hz0.3 dBmV41.6 dB00
22LockedQAM25621687000000 Hz0.1 dBmV41.5 dB00
23LockedQAM25622693000000 Hz0.0 dBmV41.6 dB00
24LockedQAM25623699000000 Hz0.0 dBmV41.6 dB00
25LockedQAM25624705000000 Hz-0.3 dBmV41.3 dB00
26LockedQAM25625711000000 Hz-0.8 dBmV41.2 dB00
27LockedQAM25626717000000 Hz-1.1 dBmV41.1 dB00
28LockedQAM25627723000000 Hz-1.5 dBmV40.8 dB00
29LockedQAM25628729000000 Hz-1.7 dBmV40.0 dB00
30LockedQAM25629735000000 Hz-1.8 dBmV39.4 dB00
31LockedQAM25630741000000 Hz-2.3 dBmV38.2 dB00
32Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA65120 Ksym/sec24600000 Hz47.5 dBmV
2LockedATDMA52560 Ksym/sec18000000 Hz46.3 dBmV
3LockedATDMA75120 Ksym/sec31000000 Hz48.8 dBmV
4LockedATDMA85120 Ksym/sec37400000 Hz49.8 dBmV
5Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
6Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
7Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
8Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
<tabindex=-1>Downstream OFDM Channels</tabindex=-1>
ChannelChannel IDIndicatorSubcarrier Zero FrequencyActive Subcarrier Number RangeTotal CodewordsUncorrectable Codewords
132Non-Primary428600000 Hz1528 ~ 2567794019131402
20Other0 Hz0 ~ 000
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
ChannelUpstreamIsMutedRanging StatusSubcarrier Zero FrequencyActive Subcarrier Number RangeSymbols Per FrameTx Power
1 Other0 Hz0 ~ 000 dBmV
2 Other0 Hz0 ~ 000 dBmV
Current System Time: Mon, Mar 07, 2022 15:47:40
EVENT LOG
TimePriorityDescription
2022-03-07, 11:29:46Warning (5)MDD message timeout;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-07, 11:24:03Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-07, 11:23:59Notice (6)TLV-11 - unrecognized OID;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
Time Not EstablishedWarning (5)DHCP WARNING - Non-critical field invalid in response ;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
Time Not EstablishedNotice (6)Honoring MDD; IP provisioning mode = IPv4
Time Not EstablishedCritical (3)No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
Time Not EstablishedCritical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
2022-03-07, 11:20:49Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-06, 18:15:58Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-06, 17:47:07Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
Time Not EstablishedCritical (3)DHCP FAILED - Discover sent, no offer received;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-05, 09:29:27Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
Model: C7800|Nighthawk X4S-AC3200 WiFi Cable Modem Router
Message 1 of 9
Guru
Re: C7800 Keeps Disconnecting and/or Very Slow
You have errors in the cable connections page plus your logs are indicating issues.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. I know you said you don't have an outlet but grab an extension cord and try the connection.
Message 2 of 9
Thanks for the reply @plemans ! I removed the splitter from the coax line and connected the Nighthawk directly to where coax comes into the house. Cable appears to be in good condition. WiFi dropped out multiple times since moving it.
Below is the latest Cable Connection report and Event Logs. Does this appear to be a hardware issue or ISP issue?
Cable Connection
Starting Frequency
SecurityENABLEDBPI+
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
1LockedQAM25631747000000 Hz7.3 dBmV40.1 dB278116
2LockedQAM2561561000000 Hz9.5 dBmV42.3 dB00
3LockedQAM2562567000000 Hz9.9 dBmV42.8 dB00
4LockedQAM2563573000000 Hz10.5 dBmV42.9 dB00
5LockedQAM2564579000000 Hz10.7 dBmV43.0 dB00
6LockedQAM2565585000000 Hz11.1 dBmV42.9 dB00
7LockedQAM2566591000000 Hz11.4 dBmV43.1 dB00
8LockedQAM2567597000000 Hz11.7 dBmV43.2 dB00
9LockedQAM2568603000000 Hz11.4 dBmV42.8 dB00
10LockedQAM2569609000000 Hz10.8 dBmV42.5 dB00
11LockedQAM25610615000000 Hz10.4 dBmV42.6 dB00
12LockedQAM25611621000000 Hz10.3 dBmV42.1 dB00
13LockedQAM25612627000000 Hz10.2 dBmV42.3 dB00
14LockedQAM25613633000000 Hz10.0 dBmV42.3 dB00
15LockedQAM25614639000000 Hz10.3 dBmV42.3 dB00
16LockedQAM25615645000000 Hz10.6 dBmV42.1 dB00
17LockedQAM25616651000000 Hz10.9 dBmV42.3 dB00
18LockedQAM25617657000000 Hz11.3 dBmV42.4 dB00
19LockedQAM25618663000000 Hz11.5 dBmV42.4 dB00
20LockedQAM25619669000000 Hz11.2 dBmV42.3 dB00
21LockedQAM25620681000000 Hz10.5 dBmV42.1 dB00
22LockedQAM25621687000000 Hz10.1 dBmV41.9 dB00
23LockedQAM25622693000000 Hz9.7 dBmV41.9 dB120
24LockedQAM25623699000000 Hz9.6 dBmV42.0 dB110
25LockedQAM25624705000000 Hz9.4 dBmV41.7 dB90
26LockedQAM25625711000000 Hz9.4 dBmV41.9 dB540
27LockedQAM25626717000000 Hz9.4 dBmV41.8 dB500
28LockedQAM25627723000000 Hz9.6 dBmV41.8 dB6530
29LockedQAM25628729000000 Hz9.5 dBmV41.8 dB11246
30LockedQAM25629735000000 Hz9.1 dBmV41.5 dB10896
31LockedQAM25630741000000 Hz8.3 dBmV41.1 dB14975
1LockedATDMA52560 Ksym/sec18000000 Hz39.5 dBmV
2LockedATDMA75120 Ksym/sec31000000 Hz41.8 dBmV
3LockedATDMA65120 Ksym/sec24600000 Hz40.8 dBmV
4LockedATDMA85120 Ksym/sec37400000 Hz43.0 dBmV
132Non-Primary428600000 Hz1528 ~ 2567192437525
20Other0 Hz0 ~ 000
Current System Time: Tue, Mar 08, 2022 16:40:42
EVENT LOG
2022-03-08, 12:26:25Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-08, 12:26:21Notice (6)TLV-11 - unrecognized OID;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-08, 11:52:22Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-07, 16:22:34Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-07, 16:17:43Critical (3)16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-07, 16:17:43Critical (3)Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-07, 16:17:33Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-07, 16:17:28Critical (3)16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-07, 16:17:28Critical (3)Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-07, 14:05:56Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-07, 13:52:38Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
Message 3 of 9
@FURRYe38 any suggestions on my issue here?
Message 4 of 9
Guru
You've still got some indications of line problems in the logs. And now your power is a touch high.
Not sure what splitter you had in line but your power jumped significantly from removing the one you have.
Try putting a decent quality double splitter back in line. Maybe a triple.
Just make sure its a decent quality. the channels you had issues with (hz not just channel number) cleared up but now others have errors.
Try that first.
and once you do that, clear the logs out so we know that anything new on there is from after the change. Not sure if you're log has events from befor the change.
If it doesn't help, the isp might need to check the line.
Message 5 of 9
@plemans this is the only one I've got access to at the moment and was the one I had on originally.
Antronix CMC2004H
Is there a different one you'd recommend using?
I've got a MicroCenter nearby...
Message 6 of 9
Guru
Just not quite a 7db one. You could get a double or triple and drop the power just a little bit less.
And make sure its on there tight on both ends. From changing splitters, your power cleaned up a bit on some of your channels and got worse on others.
So make sure its on there tight as well as check the end of the coax cable to make sure none of the foil or shield is hitting the copper wire.
Message 7 of 9
Here's a look at the last few days with the new splitter. Internet has dropped on us a couple of times. Wish I knew more about these logs so I could tell what's going on. Any thoughts? @plemans
CABLE CONNECTION
Starting Frequency
Startup Procedure
SecurityENABLEDBPI+
1LockedQAM25631747000000 Hz0.6 dBmV38.8 dB143862599
2LockedQAM2561561000000 Hz3.6 dBmV41.2 dB8240
3LockedQAM2562567000000 Hz4.5 dBmV42.1 dB9250
4LockedQAM2563573000000 Hz4.8 dBmV42.1 dB6810
5LockedQAM2564579000000 Hz5.2 dBmV42.3 dB4930
6LockedQAM2565585000000 Hz6.4 dBmV42.7 dB2700
7LockedQAM2566591000000 Hz6.7 dBmV42.6 dB2350
8LockedQAM2567597000000 Hz6.2 dBmV42.4 dB26262
9LockedQAM2568603000000 Hz6.2 dBmV42.5 dB28547
10LockedQAM2569609000000 Hz5.3 dBmV42.1 dB2410
11LockedQAM25610615000000 Hz4.3 dBmV41.5 dB2190
12LockedQAM25611621000000 Hz5.0 dBmV41.6 dB1610
13LockedQAM25612627000000 Hz4.7 dBmV41.8 dB860
14LockedQAM25613633000000 Hz4.2 dBmV41.4 dB520
15Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
16Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
17Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
18Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
19Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
20Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
21Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
22Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
23Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
24Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
25Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
26Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
27Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
28Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
29Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
30Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
31Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
1LockedATDMA75120 Ksym/sec31000000 Hz44.5 dBmV
2LockedATDMA52560 Ksym/sec18000000 Hz41.8 dBmV
3LockedATDMA65120 Ksym/sec24600000 Hz43.3 dBmV
4LockedATDMA85120 Ksym/sec37400000 Hz46.0 dBmV
132Non-Primary428600000 Hz1528 ~ 256724807523337
20Other0 Hz0 ~ 000
EVENT LOG
2022-03-14, 21:00:38Notice (6)DHCP Renew - lease parameters Time Protocol Servers modified;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-14, 21:00:38Error (4)DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-14, 13:27:46Warning (5)MDD message timeout;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-14, 07:19:22Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-13, 21:30:41Critical (3)16 consecutive T3 timeouts while trying to range on upstream channel 1;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-13, 21:30:41Critical (3)Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-13, 21:29:52Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-13, 21:29:31Critical (3)16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-13, 21:29:31Critical (3)Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-13, 21:28:43Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-13, 21:28:30Critical (3)16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-13, 21:28:30Critical (3)Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-13, 21:28:04Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-13, 21:28:04Critical (3)16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-13, 21:28:04Critical (3)Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-13, 21:26:56Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-13, 14:01:21Error (4)DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-13, 13:26:38Warning (5)MDD message timeout;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-12, 17:44:02Notice (6)TLV-11 - unrecognized OID;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-12, 17:44:02Warning (5)DHCP WARNING - Non-critical field invalid in response ;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-12, 17:43:56Notice (6)Honoring MDD; IP provisioning mode = IPv4
2022-03-12, 17:43:49Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-12, 17:43:44Critical (3)No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-12, 17:43:44Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-12, 17:43:32Critical (3)No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-12, 17:43:31Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-12, 17:39:44Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-12, 17:39:44Critical (3)16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-12, 17:39:44Critical (3)Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-12, 17:39:31Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
2022-03-12, 17:39:30Critical (3)16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=9c:c9:eb:87:d9:b0;CMTS-MAC=00:01:5c:b7:10:91;CM-QOS=1.1;CM-VER=3.1;
Message 8 of 9
Guru
You've got a lot of unlocked channels, errors in the line, and logs indicating line issues.
If you've done what you can on your side, time for the ISP to try.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1893 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
