Orbi WiFi 7 RBE973
Reply
C7800 - Turn Off Lights on Antenna Tips
Cookan
Follower
I want to turn off the blue lights that are on top of the four router antennas. The router is in bedroom and these bright lights make it difficult to sleep. Is it possible to disable / turn these antenna lights off without having to turn the router off each night?
Message 1 of 2
Guru
Re: C7800 - Turn Off Lights on Antenna Tips
Black electrical tape works pretty well 🙂
I did that for a bit on mine to limit the led light.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 317 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
