Orbi WiFi 7 RBE973
Reply
CAX 30 Separate 2.4GHz and 5GHz Radios
SimonSaba
Guide
I'm planning on purchasing a Nighthawk CAX30. I have several devices around the house that can only connect to a 2.4 GHz radio. The Ubee Modem/Router from Optimum cannot connect to these devices because it's trying to connect with the 5 GHz radio. It's not possible to separate the two radios with separate SSIDs. Is it possible to separate the two radios with 2 SSIDs with the Nighthawk so that I'm able to connect the 2.4 GHz only devices?
Message 1 of 3
Guru
Re: CAX 30 Separate 2.4GHz and 5GHz Radios
Yes you can disable smart connect on the CAX30
What is Smart Connect and how do I enable or disable it on my NETGEAR router? | Answer | NETGEAR Sup...
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 3
SimonSaba
Guide
Great. Thank you so much.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 537 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
