Orbi WiFi 7 RBE973
Reply
CAX30 2.4ghz not picked up by some devices and some apps dont work
Gggz
2.4 ghz wifi doesn't work on some apps and some devices. For example I can't connect my blink camera system. It was all working fine until about 3 days ago. I can't figure it out. I need internet for work.
Message 1 of 4
Gggz
Cax30 2.4 ghz wifi
Message 2 of 4
Guru
Re: CAX30 2.4ghz not picked up by some devices and some apps dont work
What channel configurations are currently set on the router?
Is Smart Connect enabled or disabled?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-...
Message 3 of 4
Gggz
Channel is set to auto
Firmware is v2.2.2.2
And the smart connect is disabled.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 404 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
