Orbi WiFi 7 RBE973
Reply
CAX30 Port forwarding rules disappear as soon as I enter them
ajman404
Tutor
CAX30 Router firmware version 1.4.12.2. When I go to port foward and hit save, it does not actually save the setting, and upon refresh the rule is gone. I also have that rule that port 0 is being forwarded and I cannot delete it. Multiple factory resets and restarts have not fixed this issue.
Message 1 of 17
Guru
Re: CAX30 Port forwarding rules disappear as soon as I enter them
What browser are you using? Happening with different browsers?
Be sure to clear out all browser caches before entering the modems web page.
How are you factory resetting the modem?
https://community.netgear.com/t5/Cable-Modems-Gateways/Cax30-port-forwarding-settings-disappear/m-p/...
Message 2 of 17
ajman404
Tutor
Tried with Chrome and Edge. Caches cleared, still no dice. Factory resetting by holding the reset button on the back of the router for 10 seconds until it power cycles.
Message 3 of 17
ajman404
Tutor
Add firefox to that list. This has to be a bug in the firmware, this sucks.
Message 4 of 17
Guru
How was the FW updated, via Auto Update or manually applied with the FW file?
Message 5 of 17
ajman404
Tutor
Auto update would not pull recent firmware, so firmware was upgraded via downloading from netgear site and uploading to the router.
Message 6 of 17
Guru
Which browser did you use to load the FW file? MS Edge or FF is recommended.
Message 7 of 17
ajman404
Tutor
Chrome. However, the firmware took just fine and is running as intended, showing updated firmware and working just fine. The only issue I have here is setting the settings for port forwarding.
Message 8 of 17
Guru
Could you do a manual re-load of the FW file to the CAX30 using MS-Edge or FF, then once the modem is back to ready, factory reset the modem and setup from scratch using this process:
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
Once you get it setup, clear out all browser caches, then try a PF configuration. Be sure to disable uPnP before setting up a PF configuration.
Message 9 of 17
ajman404
Tutor
Still no dice.
Message 10 of 17
Guru
How long have you had this modem for?
I'm thinking need to open up a support ticket and get this to NG:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/about/contact-us/
@DarrenM
Message 11 of 17
ajman404
Tutor
I've had this for roughly a year and a half - was on the phone with support related to a different issue last night and said I still had support.
Message 12 of 17
Guru
Might ask them if there is a beta FW version available that you can try.
Message 13 of 17
ajman404
Tutor
We will see. I just created a support ticket, will keep updated. Just sucks that it seems that it's literally just a bug in the software for a $500 router
Message 14 of 17
Guru
Bugs happen. Hopefully NG can get it fixed.
Message 15 of 17
ajman404
Tutor
Seems like multiple others have had this issue as well - unfortunately the fixes there did not help me in this case
Message 16 of 17
Guru
Ask to see about beta FW.
Message 17 of 17
Top Contributors
Discussion stats
  • 16 replies
  • 1569 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
