Orbi WiFi 7 RBE973
Reply
CAX80 — Nighthawk 8-Stream WiFi 6 Cable Modem Router- Ports don't work but WIFI network does
Redfieldscott
Follower
I've been having issues with my CAX80- The RJ45 Ports don't work- I've had a support ticket open and all they did was roll back the Firmware. Is anyone else having this issue? Naturally, Netgear doesn't want to help since its' just over a year old. Even though this issue and support ticket was opened before the support expired.
Message 1 of 3
Guru
Re: CAX80 — Nighthawk 8-Stream WiFi 6 Cable Modem Router- Ports don't work but WIFI network does
Be sure your using a good quality LAN cable between the modem and PC. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
So all ports tried do not work?
Do front LEDs for each port not light up and turn ON WHITE when connected too?
Message 2 of 3
Guru
did rolling back the firmware fix the issue?
Did you try a factory reset?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 367 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
