- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CAX80 Wired much slower than WIFI
- Mark as New
- Bookmark
- Subscribe
- Permalink
I get over 350Mps on my wifi however when I connect directly to the CAX80 modem/router I only get 85-90 Mps. I am connecting with a Cat6 cable which is not defective. I also have Cat 6 wired in the house and have it directly connected to a TV upstairs. Have been getting buffering with this wired connection which I did not get with my old Nighthawk router and separate Spectrum modem. Cant seem to find the correct answer to fix this anywhere! Any help??
Thx
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CAX80 Wired much slower than WIFI
And you tried a different wired PC to compare the wired results with?
What FW version is currently loaded on the CAX80?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes I have tried 2 separate PC's. My firmware is V2.1.1.4 which is says is up to date.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Using good quality LAN cables? CAT6 is recommended.
Seeting 1000Mpbs connection rates on the wired adapter status on the PCs network adapter?
And nothing else is happening on the network, like steaming or gaming when your testing this? If so, sounds like something with the LAN or WAN to LAN portion of this modem needs to be checked out by NG support. I'd ask for additional help and information regarding this. Ask about an RMA if needed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how it turns out.
