- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CAX80 won't connect to secure site
- Mark as New
- Bookmark
- Subscribe
- Permalink
with I receive a err_comnection_refused message. I can access the site using my old modem/router. This is the only site I have found an issue with but I really haven't had time to use it. Have factory reset, updated the latest firmware, done everything I can to try and fix this. The armor thing is not enabled.
To clarify any PC or Android device connected to wifi or hard wired will receive the same message. If I switch to LTE I can connect fine. If I plug in my old modem and reauthorize it I can connect fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CAX80 won't connect to secure site
Please post a copy and paste of the modems connection status page.
Does this happen with different web browsers?
Is IPv6 enabled or disabled on the modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Might try setting different DNS on the Modem under Advanced Tab/Setup/Internet. Try Cloudfare or Quad 9 and see. You'll need to reboot the modem and all devices after making this change.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Googles DNS didn't work either?
I'm curious if you put your wired PC in the DMZ on the modem does the site work then? Remove the PC from the modems DMZ after checking this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes please have them reprovision as well. DMZ maybe telling. If still can't access the site in the DMZ, seems like this would be a ISP side issue. If you can access the site in the DMZ, maybe a FW issue on the modem side.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok starting from the beginning. I've tried with IPv6 enabled and disabled. Will paste an image of the connection status. Just tried also using Cloudflare DNS address. Charter / Spectrum said they reprovisioned and verified it is not an issue on their end. Recommended contacting netgear support If I did setup DMZ correctly I still have no access to that page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. I'll recommend you make contact with NG support and reference this thread and let them know what you tried:
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
