Orbi WiFi 7 RBE973
Reply
CAX80 won’t factory reset and keeps dropping internet
RicoLino
I have been told to get in touch with @DarrenM and @olympus1625 to discuss this issue.
I have a netgear CAX80 and it just died. We have done everything possible to get it going with no success. We finally replaced it with a standalone modem and a ORBI wifi mesh system.
However, I cannot get this thing to reboot to factory specs, what gives? It’s not even two years old and has become a paperweight. I cannot sell it in good conscious this way either.
Any direction or help here would be appreciated.
Message 1 of 4
Guru
Re: CAX80 won’t factory reset and keeps dropping internet
You'll need to contact NG and get his solved. There is nothing we can help with here in the forums:
https://community.netgear.com/t5/Cable-Modems-Gateways/NOTICE-Users-with-sudden-non-functioning-CAX8...
Ask about an RMA.
Message 2 of 4
RicoLino
In another thread, with the exact same thing happened with the exact same model, the poster was advised to reach out to the two people I mentioned. See this link. https://community.netgear.com/t5/Cable-Modems-Gateways/CAX-80-won-t-factory-reset/td-p/2262541
I’m not exactly sure how to use this forum well, especially on my mobile, if you have any help on contacting them, that would be great.
Message 3 of 4
Guru
Yes, select on there user names and go to there profile pages and send them a Private Message.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 498 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
