- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CAX80 won't work at all on WOW Internet; firmware update ruined it
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CAX80 won't work at all on WOW Internet; firmware update ruined it
To FW update the CAX series the unit has to be in "Router" mode. It can't be in modem mode. The FW that is user updateable is ONLY for the router portion of the unit. The modem portion FW still comes from the ISP only. When in router mode, as long as the ISP Coax line IS connected to the CAX, the unit will not auto reboot. The Coax line doesn't have to be associated with the ISP or the modem has to be activated with the ISP, just as long as there a ISP modem signal on the line, the CAX will NOT auto reboot.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Correct, my point was that in order to update the router firmware, you have to flip it back from modem mode to router mode; doing so make the modem unusable as myself and others have described in this thread. The only way i've found to actually get the CAX80 to work is in modem mode; even after factory resets, it works just long enough for you to speed through the setup and flip it over to modem mode, if you miss that window you have to power cycle and try again or it'll just get into a state where WOW says they see the modem fine on their end and all the LED's on the front of the CAX80 show a successful connection; yet the device does not hand out any IP's and does not work at all when left in router mode. It was perfectly fine about 2 months ago, then 'something' happened as others have reported where router mode no longer works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, and after the FW is updated on the router side, then you can change it back to modem mode.
Is there a differenet cable ISP in your town or is WOW the only on? One thing you can do IF, there is a different cable ISP in town and IF you know someone using that ISP, take the CAX80 to there place. Connected it to there coax line, don't do any association with it with the ISP. If the latest CAX80 FW already on a wired PC there. If you power up the CAX80, the unit should not auto reboot and maintain long enough for you to send the FW file to update the router portion of the CAX80. If you can get the FW loaded then you can factory reset and remove it and take it back to your place. Again this is corner case if this is an option.
Over all this is a WoW issue that they need to get working. My CAX80 is working fine with my ISP in router mode. I don't have the wifi radios enabled and using a different wifi system currently.
- Mark as New
- Bookmark
- Subscribe
- Permalink
FW 2.1.3.5 was recently released back on November 5th, 2021 however it was only an update for the router side so the DOCSIS part should not be affected. I am not sure how long the users here have been affected but it may be worthwhile to downgrade FW 2.1.2.6 to see if the same issue occurs. Also, Netgear is aware of the issue and they have a product engineer looking into it. For the users affected what are the LEDs on CAX80 doing when this issue happens? Also, it would be good to get a copy of Event Logs posted so that we have a better sense of what's happening from the ISP side?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My sons CA80 stopped working. I reset it back to factory and was unable to reinstall it. I went to best buy and bought another one and spent the day making numerous calls to wow trying to install the new one. Wow sent a technician that changed some splitters outside and came inside and showed me on his meter that we had a good signal. He attempted to install both the old CAX80 and the new one to no avail. We installed an older modem router temporarily.
There is definitely something going on that this router is having a problem with WOW or the routers have turned into expensive boat anchors.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
i had been working with netgear and wow trying to find out why my sons CAX80 failed and no mine is dead.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the CAX30, and can confirm it is running smoothly on WOW.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I agree but after speaking with several reps from WOW, they all say the CAX80 is compatible which is frustrating. Since I just purchased the modem I'll be able to return it without issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
With the unit on, insert a small pin and press the reset button in for 30 seconds. Once 30 seconds is up, do not release the press on the reset button, but unplug the unit and wait 30 seconds. Then, while still holding in reset, plug the unit in and wait another 30 seconds. Then, release the pressing of the reset button.
I'd advise doing this with your ISP on the phone so they know what steps your taking.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unfortunately Spectrum isn't offered in my location, heard they were good. If I wanted to keep my CAX80, would anyone recommend ATT or EarthLink. FYI, ATT only offers their 50Mbps plan at my location.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ATT requires the use of there modem HW. And there mostly either DSL or Fiber now days so you can't use the CAX modem on there service. I'd contact Earthlink to see if there services support the CAX80.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Long story short, having the same issue as everyone else, but got so busy I took a loaner modem from WOW for the time beeing ... that modem is BS. ... I need to get this fixed somehow.
How do I contact NG support? I tried contacting them but got a message that my "complimentary technical support expired" even if my "product is (still) covered under hardware warranty". I got like 1 month till warranty expires, so I need to make it work.
Did anyone find an easy fix?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there a NG customer support number I can use to talk to them about it?
Would I return it to NG or the vendor I bought it from (it was almost a year ago and they might not take it)?
@Jinguni wrote:
It’s not a fix technically but I returned my CAX80 and bought the CAX30. I’ve been using the CAX30 for weeks without issue, was able to do the initial setup under 5 minutes. I still haven’t heard anything from WOW or NG regarding a fix for the CAX80.
