Orbi WiFi 7 RBE973
Reply
CM 600
llewis01
CM 600
After installing my cm600 cable modem with my isp. It seems that I can not login to the modem. I have tried the ip address and it tell me that connection was reset. Does the isp lock out that option after it is install on their network?
Thanks
Message 1 of 3
Accepted Solutions
llewis01
Re: CM 600
Figured out what the problem was. I always use firefox but that didn't work so I microsoft edge and that worked.
Thanks
Message 3 of 3
All Replies
djc6
Luminary
Re: CM 600
I've not heard of ISPs blocking access to http://192.168.100.1/ - what ISP do you have?
Have you tried turning it off/on and/or the reset button on back of modem?
Message 2 of 3
llewis01
Re: CM 600
Thanks
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3198 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
