Orbi WiFi 7 RBE973
Reply
CM1000 and Xfinity woes
HankEdwin
Greetings,
I have been having intermittent recurring issues with what I think is my CM1000 losing connection to Comcast's hardware. I troubleshooted and RMA'ed parts of my home network to see if that would fix it, but it didn't. I found this community just recently and have been diving in to research my issues. My WAN side connection to my ISP drops out periodically. If I powercycle the CM1000, the problem will fix itself right away. If I just leave it there - it will fix itself in 5 - 10 minutes. I found the web front-end to the CM1000 and started messing around with that. I decided to write a monitoring app that scrapes the CM1000 every few minutes and collects up the info. Trouble is, I am not very well versed in what I should be looking at to diagnose the issue. Here are some plots that I've built that cover:
  • ping (to 8.8.8.8, max, avg, and packet loss),
  • downstream SNR_MER,
  • downstream uncorrectable & correctable,
  • and the downstream & upstream power
https://imgur.com/a/vvF2cuE
Four outages occurred in the screen I've attached where the uncorrectable/correctable spiked, and also occurred where packet_loss goes non-zero. Does the SNR_MER or power values show anything meaningful? Are there other pieces of data I should collect and analyze? I'm actually having a bit of fun despite the outages digging into this stuff. I also plan on capturing info from my router, a Ubiquiti USG, to see if there is a correlation between the outages and upload/download or whatever else I can see on the USG.
Thanks
Model: CM1000|Ultra-High Speed Cable Modem—DOCSIS® 3.1 Ready
Message 1 of 6
Accepted Solutions
Guru
Re: CM1000 and Xfinity woes
Ensure there are no coax cable line splitters in between the modem and ISP service box.
Ensure you using good quality RG6 coax cable between the modem and ISP service box.
Contact the ISP and have them check the signal line and quality up to the modem and check there logs for any disconnections on your line.
Message 2 of 6
All Replies
Guru
Message 2 of 6
HankEdwin
Thanks for the help FURRYe38,
There are no line splitters and the coax cable was pulled by the ISP. Comcast is sending a technician to check their side. I'll follow-up on this after they do their part.
Message 3 of 6
Guru
Smiley Wink
Message 4 of 6
HankEdwin
Greetings,
I contacted my ISP during one of the outages and they were not able to reach the cable modem at the time. They sent out a crew which replaced the cable pull from the street to my house (8/26 timeframe). Since then, the daily outages are no longer occurring. There is an occasional blip that shows up as can be seen in the attached image post 8/26.
https://imgur.com/a/WJC58MQ
Thanks for the help
Message 5 of 6
Guru
Glad they were able to fix it.
Enjoy. Smiley Wink
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 6426 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
