Orbi WiFi 7 RBE973
Reply
CM1000 setup
bhelme
Tutor
CM1000 setup
I don't own a computer with an ethernet port. Any way to set up my modem without one?
Model: CM1000|Ultra-High Speed Cable Modem—DOCSIS® 3.1 Ready
Message 1 of 6
Accepted Solutions
Guru
Re: CM1000 setup
Ya a PC or laptop with ethernet is needed really. If you have a laptop that doesn't have a ethernet port, you can get USB to ethernet adapters from amazon, newegg and places like that and are inexpensive.
You can try to see if the ISP can associate the modem, once they do, power it OFF, connect a external wifi router to the modem. Power ON the modem first, then power ON the wifi router. Connect to wifi on the router and see if it has internet connection or access to the modems web page at 192.168.100.1
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 4 of 6
All Replies
Guru
Re: CM1000 setup
Sure. connect your router to it.
Or call your isp and have them provision it over the phone and then connect it to a router.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 6
bhelme
Tutor
Re: CM1000 setup
But the instructions say I need to activate it with my cable company before I connect my router. Interestingly, Netgear support responded rather quickly and said I do indeed need an ethernet connected computer to do the setup.
Message 3 of 6
Guru
Re: CM1000 setup
Message 4 of 6
Guru
Re: CM1000 setup
I've had them activate my modem over the phone without anything being connected. Once its activated, then you could attach a router to it and reboot the modem and then the router.
I guess it just depends on your isp.
Message 5 of 6
bhelme
Tutor
Re: CM1000 setup
I didn't even think about an adapter! That's a much better way to go!
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3803 views
  • 4 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
