Orbi WiFi 7 RBE973
Reply
CM1150v Availability
gbly
Tutor
Re: CM1150v Availability
Can You tell me what these error messages mean, I have a ton of the same error in my modem log...
RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=78:d2:94:59:70:b0;CMTS-MAC=00:6c:bc:b8:b9:cd;CM-QOS=1.1;CM-VER=3.1;
Message 26 of 37
CPTWingit
Guide
Hard to say with such little information. My best off the cuff guess would be power level issues on your coax coming into the modem. Not sure if you are using a lot of splitters or what the quality of your signal is but it could easily cause that error. Essentially, your cable modem might be trying it's best to communicate with the CTMS but can't put out enough.
Here's a thread that may give you some more info...
https://community.netgear.com/t5/Cable-Modems-Routers/CM1000-RNG-RSP-Issues/td-p/1399592
Message 27 of 37
Snipe76
Really? What is your US TX and DS RX? What is your US SNR and DS SNR? Ideally you should be at -8 to +8 DS RX / 35 to 52 US TX / > 29 US SNR / > 35 DS SNR. For the love of God don’t use an attenuator, ever.
Message 28 of 37
Snipe76
Oh one more thing. If y’all are using Xfinity Speedtest with Gig service, stop. Use speedtest.net or dslreports.com
Message 29 of 37
bunker195
I seem to be in the same place as everyone else.
Max speed is about 500 Mbs despite 1 gig connection with comcast.
I tried Negear CS, they referred me to comcast.  Comcast says all is well from their point of view.
Yes, its a new product, but, shouldn't it work as advertised?
Message 30 of 37
bTR
Re: CM1150v Availability - slow wire speed, R7000 router
I had the same exact issue earlier this week during the install of 1Gbs service, new XB6 > R7000.
I get 960Gbs directly connected to the XB6 with a PC, but when I connected the R7000 in “router” mode, I’d get 540Mbs max on any of the 4 switch ports. Put the R7000 into “access point” mode (which turns off the firewall, QoS and other router related features), and I get 950Mbs across all 4 switch ports.
Feels like a router firmware issue across the Nighthawk product line, but I don’t have data to back my theory.
Looks like I’m holding off on buying the CM1150v until this issue gets resolved, if it ever does.
Message 31 of 37
DarrenM
Sr. NETGEAR Moderator
What firmware version are you on with the R7000?
DarrenM
Message 32 of 37
bTR
On the latest: V1.0.9.64_10.2.64
I’m aware that dropping back to V1.0.7.6 supposedly solves the issue, haven’t gotten that far down the road yet. Plan was to get the CM1150v and see where I end up, but now thinking I may have to go that route.
Message 33 of 37
DarrenM
Try reverting back to the .42 firmware see if the speed issue is fixed.
DarrenM
Message 34 of 37
mas9973
Tutor
It looks like I may be the only one that may be getting the correct download/upload speeds with the CM1150V. I'm using a NETGEAR RAX120 Router, and I'm getting about 960 Mbps down, and 43 up, wired, through the router. I activated it using the link provided, and didn't have to call Comcast.
I hope everyone else is able to resolve their issues, as I'm really loving this modem, and my RAX120 router combined.
Message 35 of 37
gbly
Tutor
I Thought that router hasen't been released yet?
Message 36 of 37
mas9973
Tutor
As of now, the RAX120 is only available through the NETGEAR Premier Membership Beta Program, which is a type of leasing program. I was invited to participate in the program.
Message 37 of 37
Top Contributors
Discussion stats
  • 36 replies
  • 7721 views
  • 7 kudos
  • 12 in conversation
Announcements
Orbi WiFi 7
