Orbi WiFi 7 RBE973
Reply
CM1200 Modem to RBR20 Speed Issue
copco
I've been having speed issues.  Xfinity tech was here earlier and tested 1255 directly off the coax.  He could not pull a reading from the modem directly. I have the Orbi connected directly and the speed I get via the app (iPhone) is ~495/42.  I think that reading is not via wireless, but directly from within the Orbi to the modem.  If so, then clearly I am losing a lot of speed.
Can anyone direct me on the steps I need to take to close that gap?  I just updated the Orbi firmware.
Thank you,
- N
Model: CM1200|Nighthawk Multi-Gig Speed Cable Modem
Message 1 of 2
Guru
Re: CM1200 Modem to RBR20 Speed Issue
With a wired ethernet PC directly connected to the CM modem with out the RBR online, what is your speed seen with Ooklas installable speed test app? Then try with a wired PC connected to the RBR in line with the CM modem.
WiFi speeds will max out at around 400-500Mpbs on 5Ghz AC due to the 2x2 antenna design on phones and pads. 4x4 antenna design can't see over 500Mpbs.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 391 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
