× We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that may have resulted in an interruption of internet service. For instructions to restore Internet connectivity click here.
× NETGEAR would like to hear from you about specific features so we can improve your experience. To participate in this survey please click HERE.
Reply
CM2000 all lights flashing, no internet
lostdoc
Tutor
I am in a similar boat - the second time in 8 months that the device has completely bricked. I dont understand what on earth I am doing wrong - they are in a totall open ventilated space, connected to a surge protected socket. I moved sockets to accomodate a new plug and it bricked it. I am on the phone with customer support again despite telling them I have gone through this. I will try one final time (though I will refuse to pay for a replacement) and if not, will try to seek a refund via my credit card company. Absolutely absurd.
Message 2 of 5
lostdoc
Tutor
Re: CM2000 All lights flashing rapidly, no network connection
This is the second CM2000 in 8 months of owning them that I have had the device 'brick'. All lights are flashing white and all I did was move the plug to a different socket. Its unbelievable. I am going to see if a third device works if not, I am going to try to see if I can claim back via Amex.
Message 1 of 5
lostdoc
Tutor
Re: CM2000 all lights flashing, no internet
Keep at them - I think they know it’s a problem so they may extend a replacement. Otherwise, should try to see if your credit card (if you paid that way) can do chargebacks…
Message 3 of 5
Jmcieri
Tutor
They won’t extend a replacement but the credit card thing may work. Thanks.
Message 4 of 5
Guru
Were you able to get in contact with NG support and check on a RMA?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1583 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
