Orbi WiFi 7 RBE973
Reply
CM2000 blinking downstream light issue with log events
Puch96
Guide
Hello.
I was wondering if anyone is experiencing an issue with Netgear CM2000 cable modem on Xfinity.
My downstream light will blink white.  I do not have any connection issues, but I notice the following on the logs:
TimePriorityDescription
Tue Mar 30 11:05:14 2021(Notice (6))CM-STATUS message sent. Event Type Code: 22; Chan ID: 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=xxxxxxxxxx;CMTS-MAC=xxxxxxxxxx;CM-QOS=1.1;CM-VER=3.1;
Tue Mar 30 11:04:41 2021(Notice (6))CM-STATUS message sent. Event Type Code: 20; Chan ID: 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=xxxxxxxxxx;CMTS-MAC=xxxxxxxxx;CM-QOS=1.1;CM-VER=3.1;
Tue Mar 30 09:17:03 2021(Notice (6))CM-STATUS message sent. Event Type Code: 22; Chan ID: 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=xxxxxxxxxxx;CMTS-MAC=xxxxxxxxx;CM-QOS=1.1;CM-VER=3.1;
Tue Mar 30 09:16:28 2021(Notice (6))CM-STATUS message sent. Event Type Code: 20; Chan ID: 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=xxxxxxxxx;CMTS-MAC=00:01:5c:71:9e:7c;CM-QOS=1.1;CM-VER=3.1;
Tue Mar 30 09:07:53 2021(Notice (6))CM-STATUS message sent. Event Type Code: 22; Chan ID: 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=xxxxxxxxx;CMTS-MAC=xxxxxxxxx;CM-QOS=1.1;CM-VER=3.1;
Tue Mar 30 09:07:25 2021(Notice (6))CM-STATUS message sent. Event Type Code: 20; Chan ID: 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=xxxxxxxxx;CMTS-MAC=xxxxxxxxx;CM-QOS=1.1;CM-VER=3.1;
Here is my channel info:
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel507000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnabledBPI+
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
1LockedQAM2565507000000 Hz-2.5 dBmV40.6 dB00
2LockedQAM2562489000000 Hz-2.0 dBmV40.7 dB00
3LockedQAM2563495000000 Hz-2.0 dBmV40.7 dB00
4LockedQAM2564501000000 Hz-2.1 dBmV40.7 dB00
5LockedQAM2566513000000 Hz-2.7 dBmV40.5 dB00
6LockedQAM2567519000000 Hz-2.9 dBmV40.4 dB00
7LockedQAM2568525000000 Hz-2.9 dBmV40.5 dB00
8LockedQAM2569531000000 Hz-2.9 dBmV40.5 dB00
9LockedQAM25610537000000 Hz-3.0 dBmV40.4 dB00
10LockedQAM25611543000000 Hz-3.1 dBmV40.4 dB00
11LockedQAM25612549000000 Hz-3.3 dBmV40.2 dB00
12LockedQAM25613555000000 Hz-3.4 dBmV40.2 dB00
13LockedQAM25614561000000 Hz-3.3 dBmV40.2 dB00
14LockedQAM25615567000000 Hz-3.4 dBmV40.0 dB00
15LockedQAM25616573000000 Hz-3.4 dBmV40.0 dB00
16LockedQAM25617579000000 Hz-3.6 dBmV40.0 dB00
17LockedQAM25618585000000 Hz-3.9 dBmV39.9 dB00
18LockedQAM25619591000000 Hz-4.0 dBmV39.8 dB00
19LockedQAM25620597000000 Hz-3.9 dBmV39.9 dB00
20LockedQAM25621603000000 Hz-3.9 dBmV39.9 dB00
21LockedQAM25622609000000 Hz-3.9 dBmV39.9 dB00
22LockedQAM25623615000000 Hz-3.8 dBmV39.9 dB00
23LockedQAM25624621000000 Hz-3.5 dBmV40.0 dB00
24LockedQAM25625627000000 Hz-3.2 dBmV40.2 dB00
25LockedQAM25626633000000 Hz-2.8 dBmV40.3 dB00
26LockedQAM25627639000000 Hz-2.9 dBmV40.1 dB00
27LockedQAM25628645000000 Hz-2.8 dBmV40.1 dB00
28LockedQAM25629651000000 Hz-2.9 dBmV40.2 dB00
29LockedQAM25630657000000 Hz-2.9 dBmV40.2 dB00
30LockedQAM25631663000000 Hz-3.0 dBmV40.1 dB00
31LockedQAM25632669000000 Hz-3.0 dBmV40.1 dB00
32Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
Upstream Bonded Channels
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA1512035600000 Hz48.0 dBmV
2LockedATDMA2512029200000 Hz46.8 dBmV
3LockedATDMA3512022800000 Hz46.8 dBmV
4LockedATDMA4512016400000 Hz45.8 dBmV
5LockedATDMA5256040400000 Hz47.3 dBmV
6Not LockedUnknown000 Hz0.0 dBmV
7Not LockedUnknown000 Hz0.0 dBmV
8Not LockedUnknown000 Hz0.0 dBmV
Downstream OFDM Channels
ChannelLock
Status
Modulation /
Profile ID
Channel
ID
FrequencyPowerSNR /
MER
Active Subcarrier
Number Range
Unerrored
Codewords
Correctable
Codewords
Uncorrectable
Codewords
1Locked0 ,1 ,2 ,337690000000 Hz-2.5 dBmV39.8 dB1228 ~ 28673546583143537724072
2Not Locked000 Hz0 dBmV0.0 dB0 ~ 4095000
Upstream OFDMA Channels
ChannelLock StatusModulation / Profile IDChannel IDFrequencyPower
1Not Locked000 Hz0 dBmV
Message 1 of 5
Guru
Re: CM2000 blinking downstream light issue with log events
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://highspeed.tips/docsis-events/
Message 2 of 5
Guru
Your power levels look good and you don't have much for errors.
Your log indicates an issue with channel 37 (the ofdma channel). Code 20/22 indicates fec errors and resetting.
That could cause the downstream to blink as it searches to reconnect channel 37.
If its not causing a reduction in speed or issues, I wouldn't worry about it.
If you are running into issues, then see what @FURRYe38 advised.
Message 3 of 5
Taurus2313
Guide
I would love a response to my thread about the issues I am having with this modem. I have provided log screenshots in the thread. My downstream light constantly blinks as well.
Message 4 of 5
Guru
Any progress on this?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1631 views
  • 4 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
