Orbi WiFi 7 RBE973
Reply
CM2050V - How do I log in?
sdv26
I'd like to log in and change the default password. My current setup is the CM2050V connected to an Orbi RB850. This presumably is one of the two ways they mention to access the router login. From the manual:
Connect a WiFi router to your cable modem using an Ethernet connection, and
then connect a computer to your router using a WiFi or Ethernet connection.
2. Launch a web browser.
3. Enter http://192.168.100.1
Unfortunately, when I put in that address it doesn't work. Nor does the IP that the router might have from Spectrum.
Is my only solution a direct ethernet connection to the modem?
Thanks in advance
Message 1 of 5
Accepted Solutions
Guru
Re: CM2050V - How do I log in?
So change the IP address of the RBR back to 192.168.1.1 or 192.168.0.1 then try 192.168.100.1. The Orbi system should not be in the same subnet as the modems IP address.
Message 4 of 5
All Replies
Guru
That address should work...
Message 2 of 5
sdv26
It doesn't seem to, even when I have my Orbi LAN settings as follows:
192.168.100.2 (Orbi IP)
Use Router as DHCP Server YES
192.168.100.2 to 192.168.100.254 as the Range
Message 3 of 5
Guru
Message 4 of 5
rlyon534
Actually for a new CM2000, replacing a CM1000 along with a new RAXE 500 router.  Initial setup with the app.  Everything was happy but no internet.  Used Xfinity support to verify the modem connection.  OK.  Still no internet.  Couldn't connect direct to the router using the IP address in the manuals.  192.168.1.1 worked.  Was able to resolve the internet connectivity from there.  System is alive again .  Good download speed, just under 1gb, through the router, ethernet connection.  (We'll see if that lasts.) (grin ) Thanks.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1860 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
